Camber Brace
Old Aug 6, 2003 | 06:41 PM
FSTRNU's Avatar
FSTRNU
Default Camber Brace
I just recieved my Camber Brace today and there were no directions in the box. Can someone enlighten me on how and where it mounts too. Thanks
edit: I also cant find the torque values for the mount bolts. Does anyone have them handy by any chance?
[Modified by FSTRNU, 12:03 AM 8/8/2003]
Old Aug 6, 2003 | 06:47 PM
Gary04Z06's Avatar
Gary04Z06
Default Re: Camber Brace (FSTRNU)
E-mail Dave at http://www.r-dracing.com or call them, he'll e-mail or re-send the directions. It attaches to the upper a-arm.
Old Aug 6, 2003 | 07:25 PM
914eener's Avatar
914eener
Default Re: Camber Brace (Gary96LT4)
Just e-mailed you a copy of the install instructions in PDF. Mine didn't come in the box either and I had to e-mail Dave for them.
Old Aug 6, 2003 | 11:16 PM
4GTWRK's Avatar
4GTWRK
Zach,
I just sent you an instant message.
Dave
Old Aug 7, 2003 | 11:13 AM
C4DC's Avatar
C4DC
St. Jude Donor '06
As was said in another camber brace post, be careful of the coolant temp sensor on the front of the waterpump (stock). I was careful and still broke mine off... $8 at autozone...
Old Aug 10, 2003 | 03:23 PM
Dave95C4's Avatar
Dave95C4
Default Re: Camber Brace (C4DC)
Hey guys...I ordered mine when they first came out...and I've been so busy I have yet to install it! Now that I've got a break between my summer job and starting back to school later this month, I'm thinking about doing it. I did have two questions that might be obvious, or I might have known them in the past...but I've forgotten the answers. 1. What size bolt is the front upper control arm? and 2. To what level should this bolt be torqued when reattached? Thanks in advance!
Dave
Old Aug 10, 2003 | 03:38 PM
Raysur's Avatar
Raysur
Default Re: Camber Brace (Dave95C4)
My gm manual says 37ft/lbs. for the upper a arm bolts. I just recently took mine out (waterpump replacement) Just watch out for the fitting on the ac evaporater. That could be an expensive fix.
And take your time. It does fit, so move slowly. :cheers:
Old Aug 10, 2003 | 03:39 PM
Dave95C4's Avatar
Dave95C4
Default Re: Camber Brace (Raysur)
Thanks man...I've gotta get one of those GM manuals, they're well worth the cash. I appreciate it!
Old Aug 10, 2003 | 04:16 PM
FSTRNU's Avatar
FSTRNU
I just did mine today. It wasnt too bad took longer to jack it than it did to install the brace. I recommend removing the inner wheel well cover so you can get your hands in there easier. I used the original bolt on the drivers side but had to use the supplied one on the passenger side with one shim. The bolt is a 18mm deepwell. Be careful of the coolant temp sensor on the waterpump its easy to break just be careful adn take your time its fairly simple.
Old Aug 10, 2003 | 05:49 PM
fiberglasscoffin's Avatar
fiberglasscoffin
any pics?
Old Aug 12, 2003 | 10:30 AM
Dave95C4's Avatar
Dave95C4
Hey Guys,
Looks like I need some help here...heh heh. ;) I ordered the brace when they first came out, and I didn't get two extra bolts. I'm looking at it now and it seems that the stock bolts are going to be a bit too short...any suggestions on the size I use, and/or where to get them? I guess I'm pretty much stuck until I get those... Thanks for any suggestions!
Dave
Old Aug 12, 2003 | 11:02 AM
4GTWRK's Avatar
4GTWRK
Dave95C4,
Dave Cooper
R-D Racing
Old Aug 12, 2003 | 11:14 AM
Nathan Plemons's Avatar
Nathan Plemons
When I got mine I didn't actually notice the extra bolts and shims, they were wrapped up in the paper. I found them like a month later, guess I didn't need them. :cheers:
Old Aug 12, 2003 | 01:10 PM
Dave95C4's Avatar
Dave95C4
Got Dave's instant message...always great to talk with the people at R-D. They were gracious enough to send me the bolts asap. It's nice to know of a shop that not only produces high quality products...but also provides high quality customer service. ;) Definitely some cool folks!
Dave
BTW...I'm going to go search the forums about info on getting the belt off and then back on again. It looks like a tight fit to get it back on there...anyone have any innovative tricks? ;)
Old Aug 12, 2003 | 01:14 PM
FSTRNU's Avatar
FSTRNU
You can do it without taking the belt off. I didnt have any problems with it still being in place.
Old Aug 12, 2003 | 01:19 PM
Dave95C4's Avatar
Dave95C4
FST...did you just twist it to get the bolt in/out on the driver's side?
To Camber Brace
