Road Test Report: eletric waterpump
Old Aug 6, 2003 | 07:40 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Road Test Report: eletric waterpump
Road test report
Mods:
BeCool racing radiator
160 degree stat
manual fan switch
Conditions:
90 degrees
90% humidity
in town drive
AC off, fans on
hit 180 degrees once.
AC on, fans on
hit 190 degrees once.
:cheers:
Old Aug 6, 2003 | 09:14 PM
Strick's Avatar
Strick
Default Re: Road Test Report: eletric waterpump (BrianCunningham)
Ah, another happy Mez customer. Glad it worked out for you. Any added tips for my Meziere pump install article? :cheers: :flag
Old Aug 6, 2003 | 09:22 PM
bogus's Avatar
bogus
you know... there are so many changes there, that the mez can't be isolated.
The end result tho is fantastic!
Old Aug 7, 2003 | 04:55 PM
BrianCunningham
Default Re: Road Test Report: eletric waterpump (bogus)
I've had the racing radiator, stat, and manual fan switch for a while.
The pump is making a big difference. It's spinning full blast while the car is sitting at a light.
A good 5 degrees cooler with the AC off.
15 degrees cooler with it on.
Haven't been racing yet, but the nice thing about the pump is being able to keep it running after you've pulled off the track.
Tips to add:
I used JB weld on the freeze plug and the old weep holes.
If you can find weather pack relays, use them.
Same goes with wire taps, that way you don't have cut and slice the wiring harness.
The harness that comes with pump isn't weather packed, so make sure you seal it up good and tight.
The HD pump fits with the thicker radiator, no problems.
I put a pad between it and the MAF, as per forum advice.
The hood still closes.
The relay and fuse fit nicely under the headlight, with the rest of the factory relays. That's also where I grounded the pump. Just make sure the headlights can rotate. I used zip-ties.
[Modified by BrianCunningham, 4:58 PM 8/7/2003]
Old Aug 7, 2003 | 05:44 PM
Strick's Avatar
Strick
Way to go Brian. My Mez is running great. I just hope they last as long as they say it will. Anyway, it's a snap to replace. You say you found a weather pack relay. How many amps is it rated for and where did you get it? :cheers:
Old Aug 8, 2003 | 10:04 AM
ralph's Avatar
ralph
Default Re: Road Test Report: eletric waterpump (Strick)
I just finished installing one on my L98, and it's quite a bit more involved than the LT1 install. It hasn't been all that hot since the install, but my initial observations are that it might be a few degrees cooler at idle and a few degrees hotter at cruise, but man it cools down quick between rounds.
[Modified by ralph, 10:05 AM 8/8/2003]
Old Aug 8, 2003 | 10:07 AM
bogus's Avatar
bogus
Ok, I stand corrected!
I was under the impression you did ALL of that at once! :cheers:
Old Aug 8, 2003 | 10:08 AM
vvv90's Avatar
vvv90
Default Re: Road Test Report: eletric waterpump (ralph)
:cheers: glad to hear it all worked out for you.
Old Aug 8, 2003 | 12:40 PM
Strick's Avatar
Strick
Any info on that weather pack relay?
Old Aug 8, 2003 | 06:33 PM
BrianCunningham
Summit has them
BGI-171035 30 amp fuel pump relay and harness
or
NOS-15618 30 amp relay switch with harness
Old Aug 8, 2003 | 07:31 PM
loiq's Avatar
loiq
What kind of switch did you use for your fans?
Old Aug 9, 2003 | 06:24 AM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
Default Re: Road Test Report: eletric waterpump (loiq)
Any performance increases?
Old Aug 9, 2003 | 02:49 PM
BrianCunningham
Default Re: Road Test Report: eletric waterpump (Bruthish)
I bought the Mid-America switch. Nice kit, comes with weather tight wires taps, so you don't have to cut the harness.
I haven't dynoed it yet, but it definitely revs faster.
Old Aug 9, 2003 | 04:39 PM
TheStef's Avatar
TheStef
Has any one ever tested the car before and after changing the termostat to a 160 degree?
how about the 1/4 mile ? or 0 to 60?..... I was told the engine runs stronger when cooler, but I was also told that the engine being cooler won't let the fuel spray dispurse properly.
hmmmmm has any one ever hurd of this before?
Old Aug 9, 2003 | 07:44 PM
ericcer's Avatar
ericcer
Default Re: Road Test Report: eletric waterpump (TheStef)
Having the car running cooler makes it much more consist at the track. I have a 160 degree thermostat. One time at the track I programmed the fans to come on at 170 instead of my normal 180 and I did 3 runs back to back with the same ET and MPH down to a few hundredths of a second.
Keep in mind this is with a stick shift and I am no great driver.
[Modified by ericcer, 7:45 PM 8/9/2003]
To Road Test Report: eletric waterpump
