91 vette fastchip
Old Aug 6, 2003 | 10:47 PM
6spd's Avatar
6spd
Default 91 vette fastchip
hope someone can help i bought a custom chip to go with my mods including a set of 24lbs injectors that i just installed after i was done installing my injectors i left the stock chip in i didn't replace it yet i turned the key on did not start car i wanted to pressurize the system any everything worked well was holding great no leaks when i installed the fastchip and turned the key on fuel pressure went up then droped all the way down it's not holding is there somthing wrong with the chip????
Old Aug 6, 2003 | 11:17 PM
atotalnincompoop's Avatar
atotalnincompoop
Default Re: 91 vette fastchip (6spd)
sounds like an injector leak, are they accel injectors?
i've heard the o-rings on those can leak :yesnod:
Old Aug 6, 2003 | 11:24 PM
6spd's Avatar
6spd
Default Re: 91 vette fastchip (atotalnincompoop)
no they are ford svo everything was fine with the stock chip it's when i installed the new chip
Old Aug 7, 2003 | 03:49 AM
Larrym96815's Avatar
Larrym96815
It is only about a five minute job to put the old chip back in and try it. That would tell you for sure.
Aloha,
Larry
Old Aug 7, 2003 | 08:03 PM
6spd's Avatar
6spd
Default Re: 91 vette fastchip (Larry Mackey)
everything is perfect when i started the car it pressurized and it held i wasn't being paticent
Old Aug 7, 2003 | 10:49 PM
Steel Blue 91's Avatar
Steel Blue 91
:iagree:
The new chip shouldn't have anything to do with your fuel system not holding pressure. Double check the injectors and "o" rings.
To 91 vette fastchip
