Superfueler and superram
Old Aug 8, 2003 | 12:59 AM
Oden's Avatar
Oden
Default Superfueler and superram
Hi..
Anyone has a Carroll Superfueler on a superram intake?
Does anyone know if the superram distribute wet intake air good to all cylinders?
Dont want to spend $$$ and then switch back to my FMU.....
/N.
Old Aug 8, 2003 | 10:29 AM
krivera's Avatar
krivera
Default Re: Superfueler and superram (Oden)
:nonod:
Old Aug 8, 2003 | 05:40 PM
black bart's Avatar
black bart
Using a superfueler or fmu is like puting a rubber liner in your shirt pocket because your ink pen is leaking. It will work but it is by far not the best solution. Instead of jacking the fuel pressure sky high use larger injectors and tune the ECM till you have the correct A/F ratio When GM came out with the LT-4 they didn't jack the fuel pressure they used bigger injectors and different ecm. Company's selling superchargers use those devices because if they done it right the increased cost of their kits would scare away a lot of sales so they use the elcheapo solution. If you are not making big power numbers you can run those things but once you get serious about power then their shortcoming's will force you to go to a tunable ecm.
To Superfueler and superram
