zelement
Old Aug 8, 2003 | 12:39 PM
devilfish's Avatar
devilfish
Default zelement
what have you done to yout engine?
thanks
Old Aug 8, 2003 | 02:04 PM
Mr. Magoo's Avatar
Mr. Magoo
From: Damn taxes! Pimpin' Ain't Easy in Massachusetts
2018 C4 of Year Finalist
St. Jude Donor '03-'04-'08-'09
Default Re: zelement (devilfish)
:lurk:
Old Feb 10, 2022 | 02:13 PM
1981HandMeDown's Avatar
1981HandMeDown
3rd Gear
Worked in the fire protection industry for 20+ years. if it was Sodium Bicarbonate, (BC dry chemical white or very light blue in color) I would change the filters and change the oil and call it a day. Avoid water when cleaning up... vacuum or a tack rag is your best bet.
If your hypothetical issue was ABC Dry Chem (Monoammonium phosphate) which is light yellow in color I would do the above PLUS deep clean vacuum, can air any electrical connections, as it will slowly and mercilessly corrode copper and zinc.
Old Feb 10, 2022 | 03:56 PM
383vett's Avatar
383vett
I think you've earned the award for oldest threat revival. 19 years sets a new record.
Old Feb 10, 2022 | 04:21 PM
1981HandMeDown
3rd Gear
I didn't see a good answer! hahaha
Old Feb 11, 2022 | 04:25 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Thread closed.
Old Sep 16, 2025 | 03:26 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
To zelement
