My battery light came on...
Old Aug 9, 2003 | 08:29 AM
Sal Collaziano's Avatar
Sal Collaziano
Default My battery light came on...
Hey. What's that? I forget what my charge was so I guess I'll have to go take a look. But does this generally mean the alternator or battery is going?
Thanks in advance...
Old Aug 9, 2003 | 08:35 AM
Sal Collaziano
Default Re: My battery light came on... (Sal Collaziano)
I think I just found my answer.. If I remember correctly, it was low at around 12 volts or so.. I think I'll probably need an alternator... Is this difficult to change on your own? I never really do any repairs myself... How much is an alternator plus installation at say, PepBoys? :p
Old Aug 9, 2003 | 08:46 AM
MITCH's Avatar
MITCH
sal don't use a pep boys alt buy a ac delco reman alt it is a better alt. if you are handy with tools you can change the alt in about 20 mins tops. hope this helps.
mitch
speednut2@aol.com
:steering:
Old Aug 9, 2003 | 08:52 AM
Steel Blue 91's Avatar
Steel Blue 91
You can DIY and save some bucks. The alt. isn't that hard to do. Had to do mine last Sunday. The only thing that complicated mine was the Camber Brace. Added about ten min. to the process. I opted for a reman. unit from Advance Auto with a lifetime replacement warranty for $112 (+ $35 core). Go ahead and replace the belt at the same time. The total for the parts (after returning the core) was $145. Estimate from Mr. Goodwrench, $345 - I don't think so.
Old Aug 9, 2003 | 11:51 AM
Sal Collaziano
Is there ANY possibility that this can have something to do with the fact that sometimes I'm not getting much air blowing out of the vents?
Old Aug 9, 2003 | 01:54 PM
jfb's Avatar
jfb
The fan will run slower on lower volts, but not slow enough for you to notice. You need to look for the vacuum doors opening correctly or measure the fan motor voltage on high. Clean debris out of the heater core.
Old Aug 9, 2003 | 03:13 PM
Sal Collaziano
Default Re: My battery light came on... (jfb)
Thanks for all the help everyone. I guess it was just wishful thinking that I could kill two birds with one stone...
Old Aug 11, 2003 | 12:04 PM
Sal Collaziano
Old Aug 11, 2003 | 12:51 PM
PreferEuroRacing's Avatar
PreferEuroRacing
It looks like the 'Vette alt is much easier than the Probe GT that I had before. For that alternator, you had to remove the right wheel, inner wheel liner, brake and hub assembly and the axle!!. I looked the project over and gave up before I started. Had to pay $350 to have it done.
Old Aug 11, 2003 | 03:07 PM
Jim85IROC's Avatar
Jim85IROC
Default Re: My battery light came on... (PreferEuroRacing)
Even if you're mildly retarded you should be able to change an alternator with very little trouble.
To My battery light came on...
