Jacking up front....
Old Aug 9, 2003 | 09:17 AM
TomHamill's Avatar
TomHamill
St. Jude Donor '05
Default Jacking up front....
.... is it possible or recommended to use a floor jack to raise entire front of Vette to place jackstands ?
Old Aug 9, 2003 | 09:22 AM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: Jacking up front.... (TomHamill)
Yes. Just place the floor jack at the jack points and raise away. Place jack stands on the frame (inboard and to the rearof each front wheel). You'll need to do one side at a time.
[Modified by Steel Blue 91, 9:23 AM 8/9/2003]
Old Aug 9, 2003 | 09:48 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Here's a tip, drive up on some 2 x 6's first, that will give you enough clearance to slide the jack underneath.
Old Aug 9, 2003 | 11:05 AM
minnasotajim's Avatar
minnasotajim
:iagree:
Has worked great on both suggestions.
To Jacking up front....
