Cut wires?
Old Aug 9, 2003 | 05:58 PM
TxAgNavyVette96's Avatar
TxAgNavyVette96
Default Cut wires?
I have a small group of wires that I found cut. They are a grey shroud with a yellow and red wire inside. I found them running behind the seat. The non-cut side runs to the square carpet piece on the inside drivers side sill area. I went out but could not find the tech manual anywhere. Does anyone know what this is or where I can find an online tech manual.
Old Aug 9, 2003 | 05:59 PM
TxAgNavyVette96
Default Re: Cut wires? (TxAgNavyVette96)
Sorry, I didn't add this is a 96' coupe.
Old Aug 10, 2003 | 01:46 PM
TxAgNavyVette96
Is there anyone out there that can help? I would like to know what these wires are affecting. :eek:
Old Aug 10, 2003 | 02:30 PM
Scott's 86's Avatar
Scott's 86
Without looking at my Haynes manual which is at work, I could guess by the grey shroud that they might be the oold wire to the rear speakers. Do you have an aftermarket stereo?? I'll let you know more once I look it up at work. Hope this helps.
Scott
:cheers:
Old Aug 10, 2003 | 02:46 PM
JasonL's Avatar
JasonL
Guessing from the location, how about the parking brake warning light. Does the "PARK" dash light come on when you set the parking brake?
Old Aug 10, 2003 | 07:18 PM
Red Dwarf's Avatar
Red Dwarf
Looking at the harness routing view, 95 coupe, it could possibly be the L/H speaker harness. Try opening the pass/storage compartment & look under the plastic former at the radio receiver to see if the colored wires are hooked up to the radio receiver. The colors you gave don't match the manual speaker wire color, so far as I can tell.
Old Aug 11, 2003 | 12:18 PM
TxAgNavyVette96
It looks like it runs to the speaker and I do have an aftermarket cd player. I don't know about the speakers though. I will check it out when I get the book and some free time. Thanks for the info.
To Cut wires?
