89 vert rear shock question.
Old Aug 9, 2003 | 08:19 PM
CountryBoy's Avatar
CountryBoy
Default 89 vert rear shock question.
I have the wheels off and can see that the oil is leaking from the factory Bilsteins. I'm going with KYB's next.
I see the lower bolt no problem, but the top goes through the rear compartment of the back storage area. Do I have to remove the interior carpet to get to this nut/bolt? I see two nuts on each side of the shock shaft where it goes through the bottom of the car. Are these the only two top bolts/nuts I need to remove to change shocks? :confused:
Old Aug 9, 2003 | 08:27 PM
chucks88's Avatar
chucks88
Default Re: 89 vert rear shock question. (CountryBoy)
If my memory serves me those are the only to bolts on top. No need to enter the car to rip out the carpet either :nonod:
Old Aug 9, 2003 | 08:29 PM
CountryBoy's Avatar
CountryBoy
Default Re: 89 vert rear shock question. (chucks88)
Yea baby! :cheers: Thanks, that's makes it even easier. :seeya
To 89 vert rear shock question.
