Dialectric grease?
Old Aug 9, 2003 | 08:24 PM
95AquaC4's Avatar
95AquaC4
Default Dialectric grease?
Anyone use that clear grease stuff that comes with some wire sets? What's it's use?
Old Aug 9, 2003 | 08:26 PM
PoloGrnC4's Avatar
PoloGrnC4
Default Re: Dialectric grease? (95AquaC4)
Keeps the boots from sticking to the plugs. Works really good.
Old Aug 9, 2003 | 08:32 PM
c4cruiser's Avatar
c4cruiser
It also works great on weatherstripping to keep it from drying out and cracking. Just a very small amount on your finger and rub into the weatherstripping. Let it sit for an hour or so and then wipe off with a clean cotton cloth. No squeaks and it will look like new!!
Old Aug 9, 2003 | 09:07 PM
jtfrog's Avatar
jtfrog
i use it on all of my electrical connections
Old Aug 9, 2003 | 09:12 PM
Strick's Avatar
Strick
Default Re: Dialectric grease? (jtfrog)
Can you buy it in larger quantities? Those little tubes don't last too long.
Old Aug 9, 2003 | 09:23 PM
cprgmr's Avatar
cprgmr
Default Re: Dialectric grease? (PoloGrnC4)
:iagree: It also keeps the boots from sticking to the opti! :)
Old Aug 9, 2003 | 09:24 PM
cprgmr's Avatar
cprgmr
Default Re: Dialectric grease? (Strick)
Not sure, you could call Autozone, Napa, Advance, or Checker to see...
Old Aug 9, 2003 | 09:26 PM
c4cruiser's Avatar
c4cruiser
Permatex makes a number of sizes of tubes. I bought a couple of the .33 oz tubes and I used less than half of one tube for my new plug wires and all the weatherstripping on my 92 vert. A little goes a long way!
The Permatex stuff is called "Dielectric Tune-up Grease" and has a part number of "67VR' on the tube.
Old Aug 9, 2003 | 09:28 PM
95AquaC4's Avatar
95AquaC4
Thanks! :cheers:
Old Aug 9, 2003 | 09:29 PM
LT4BUD's Avatar
LT4BUD
I have a can of it, so it is available in larger quantity. I found mine a year or so ago in my car after it had been serviced at the dealership. They used it on the weather-stripping.
So maybe an auto supply house or electrical supply might have the larger quantity
Old Aug 9, 2003 | 09:33 PM
Strick's Avatar
Strick
Default Re: Dialectric grease? (LT4BUD)
Thanks Bud
Old Aug 9, 2003 | 10:16 PM
LaVidaLoca's Avatar
LaVidaLoca
Can't remember where I got mine either.
Another good use for it: put it inside heater and radiator hoses on the ends. Makes them easier to slip on AND it keeps them from sticking to the fitting so you can get them off. Oh yeah, inside spark plug boots to keep them from sticking. :thumbs:
It looks like there is a bunch of uses for this stuff. Almost as useful as duct tape or post-its.
[Modified by LaVidaLoca, 9:19 PM 8/9/2003]
Old Aug 9, 2003 | 10:19 PM
Strick's Avatar
Strick
Default Re: Dialectric grease? (LaVidaLoca)
Gee, this stuff is like Witch Hazel :cool:
Old Aug 10, 2003 | 03:29 AM
BIG JIM 54's Avatar
BIG JIM 54
Another word for "Dielectric Grease" is "Silcone Grease" if that helps.
BIG JIM
Old Aug 10, 2003 | 03:08 PM
scorp508's Avatar
scorp508
Default Re: Dialectric grease? (BIG JIM 54)
Any of your normal auto parts stores will have big tubes of this stuff. Autozone, pepboys, napa, you name it.
Old Aug 10, 2003 | 06:21 PM
Sparky_OKC's Avatar
Sparky_OKC
Someone suggested 'Leslie's Pool and Tub Lube' [I know, that name just doesn't sound right...] because it has DuPont Krytox. It seems to work well, and at about $5-6 for 3.5 oz, it's not a bad deal.
Old Aug 11, 2003 | 12:59 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default Re: Dialectric grease? (cprgmr)
Yes, you can get silicone or bum grease in bulk at HomeDepot, or NAPA auto parts stores. :thumbs: Works great on weatherstripping as others have said!
To Dialectric grease?
