Battery question
Old Aug 9, 2003 | 09:57 PM
dbwade36's Avatar
dbwade36
Default Battery question
I have an Optima Red Top battery that is less than a year old. Everytime I go away for a week or so, when I come back the battery is dead. It recharges and is fine. Is this common, or do I have a problem?
Old Aug 9, 2003 | 10:05 PM
Strick's Avatar
Strick
Default Re: Battery question (dbwade36)
How's things at Travis? Here something to try. The next time you go TDY, disconnect the battery. When you get home, reconnect it and see if it still has a charge. If not, buy a good trickle charger. :flag :flag :flag
Old Aug 9, 2003 | 10:22 PM
don hall's Avatar
don hall
... Is this common, or do I have a problem?.....
Not common, and you have a problem either with the electrical system, or the battery. The draw (computer/clock) on an idle battery is about 25 milliamps. Batt should stay charged 3-4 weeks.
Before getting involved with an electrical system check, pull the batt and have it tested under load.
Old Aug 9, 2003 | 10:35 PM
jfb's Avatar
jfb
You have a current drain that is way too high. Connect an ammeter in series with one of the battery cables and wait for the courtesy lights to time out, then reduce the full scale reading of the ammeter and measure the "off" current. It should be less then 50 ma. (milliamps) or something is drawing current. If your battery discharges in 5 days, the current required to do this is about 0.25 amps (250 milliamps). You can pull fuses one at a time while observing the ammeter and one should make the current drop dramatically. That is the circuit that you will have to further investigate to find the leakage current.
To Battery question
