l98 starts rough, idles rough today
Old Aug 9, 2003 | 11:16 PM
90qzrblu's Avatar
90qzrblu
Default l98 starts rough, idles rough today
The vette has been running fine until today. I started it up this evening, and it is stumbling. Check engine light comes on. The exhaust smells real rich. Where should I start checking? I'm thinking spark. The car has 66k on it, and I think the plugs and wires are still the original ones. What else could I check?
thanks,
chris
Old Aug 9, 2003 | 11:19 PM
vader86's Avatar
vader86
Default Re: l98 starts rough, idles rough today (90qzrblu)
How about you pull the code first.
Old Aug 9, 2003 | 11:43 PM
90qzrblu's Avatar
90qzrblu
Default Re: l98 starts rough, idles rough today (vader86)
ok, i'll try that tomorrow afternoon.
Old Aug 9, 2003 | 11:47 PM
MtlSphere's Avatar
MtlSphere
:iagree:
I'm expecting to see a O2 code... 13?
:seeya
Old Aug 10, 2003 | 02:29 AM
vader86's Avatar
vader86
Default Re: l98 starts rough, idles rough today (MtlSphere)
i'm leaning towards MAF right now
crap, no MAF on 90-91. hmmmmmmm
[Modified by vader86, 9:30 AM 8/10/2003]
Old Aug 10, 2003 | 07:20 AM
apollo30346's Avatar
apollo30346
I'm thinking O2...... :yesnod:
Old Aug 10, 2003 | 07:51 AM
ELEVENS's Avatar
ELEVENS
Read the code(s). But here's my predictions:
The car doesn't use feedback from the O2 sensor until going closed loop (about three minutes after starting up a cold motor). SO even though it's probably time for a new O2 sensor, I don't think a bad one will make your car run crappy when cold.
If I'm reading your handle correctly, you have a 1990. No MAF on a 90. But a crummy MAP will make the car practically unable to run. Thing is, MAPS are very reliable.
I'm guessing plug or plug wire. After 66,000 miles, man, it could use a tune up!
Do we get a prize for guessing correctly?! Be sure to let us know what you find.
[Modified by ELEVENS, 7:55 AM 8/10/2003]
Old Aug 10, 2003 | 04:39 PM
FullShred's Avatar
FullShred
I had this happen a couple years ago on my '90. I pulled up to a stop light, it's idling great, then all of the sudden it's idling rough as h**l. I got it home, the exaust smells rich. I can't remember if it set a code or not. I pulled the plugs and found #7 wet with gas. The injector was stuck wide open.
Good luck,
Bill
Old Aug 10, 2003 | 05:58 PM
nitrous1's Avatar
nitrous1
St. Jude Donor '06-'07-'08-'09
Try checking your fuel pressure. If the fuel pressure regulator goes bad, the fuel pressure will be too high at the injectors and blow right past them, causing the car to run rich. Happened to my 86 last year.
Good luck
Dan
Old Aug 11, 2003 | 08:52 PM
90qzrblu's Avatar
90qzrblu
Default Re: l98 starts rough, idles rough today (nitrous1)
Ok, i finally read the codes and got these:
15,21,43,53
The 21 and 43 are probably the ones I'm after. 21 is "throttle position sensor high" and 43 is "knock sensor circuit".
I would suppose that it spits these out in numerical order, and not the order in which the error occurred?
How do I check the throttle position sensor to adjust or replace? Also, where is the knock sensor and what does it do?
thanks alot guys,
chris
Old Aug 11, 2003 | 11:29 PM
vader86's Avatar
vader86
15- Coolant sensor circuit, has your coolant temperature been freaky or too high?
21-TPS, check its voltage and the connections first, then youll probably have to replace it
53-system voltage too high
43-Knock sensor, check for wiring shorts to ground and make sure wiring clears the exhaust, then replace the knock sensor
The knock sensor is VERY important, if it reads knock the ECM adjusts timing so you dont cook a piston.
All of these seem like voltage problems, so start at the TPS first, and that one might be triggering all these other codes. You always start at the front of the engine when it comes to SES codes. Clear the codes after fixing the TPS and see what comes back. I bet some of them disappear. The TPS sensor is on the side of the TB
Old Aug 15, 2003 | 02:25 PM
90qzrblu's Avatar
90qzrblu
Ok, I got the TPS sensor changed, and still nothing different. I did notice that the engine sounds like I've got a supercharger on it. Like a whistling that changes pitch with RPM. Maybe I've got a huge vaccuum leak? Would that cause codes like what I got?
Old Aug 15, 2003 | 02:52 PM
vader86's Avatar
vader86
the code 21 came back after you cleared them?
a vacuum leak might cause the 21 if the wiring is good, then that triggers the rest
Old Aug 17, 2003 | 08:52 PM
90qzrblu's Avatar
90qzrblu
Well, I changed the TPS on thursday. Still ran rough. I went back out today (sunday), cleared the codes out, and it idles just fine now!!!
:party: :party: :party:
Thanks alot, Vader! I've got my vette back now.... :D
To l98 starts rough, idles rough today
