Dyno elvation/temp etc correction factors?
Aug 11, 2003 | 01:56 AM
St. Jude Donor '03 & '05
Are there corrections for weight, temperature elevation etc for dyno runs? Just curious as there are for 1/4 mile times and speed. I used a Dyno Jet, and was curious as the elevation, based on weather stations is 1500 feet here in Hawaii. Dont ask me how, okay, it is just what the weather people say.
Aug 11, 2003 | 03:20 AM
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Re: Dyno elvation/temp etc correction factors? (steve40th)
The temperature and elevation corrections would be the same as for 1/4 mile runs.
As far as weight, I have no idea.. there's some rough calcs that predict 1/4 mile speed and ET based on HP.
Also, consider aero horsepower (drag) if you're trying to predict 1/4 mile times.
I have all the calcs on my computer, they're pretty scary looking equations. Relative Humidity, dewpoint, virtual vapor pressures, all kinds of crap.
if you give me the weather readings and the rwhp output i can tell you the corrected rwhp and bhp.
Aug 11, 2003 | 11:15 AM
Re: Dyno elvation/temp etc correction factors? (CentralCoaster)
Temp was 90 degrees, elevation 1500, dew point 66, HG 30 in, but I dont know Virtual vapor here in hawaii. Rwhp was 400.
Aug 12, 2003 | 12:48 AM
i need the humidity also.
this determines the virtual vapor pressure i think. I don't remember the equations exactly, I put em all in Excel.
But gimme a guesstimate on humidity and i'll plug it in to the formula. It doesn't affect it that much, but every bit of accuracy is helpful.
That sounds like it'll be a really high DA! That means your horsepower will go up considerably. :cheers:
Aug 12, 2003 | 12:49 AM
1500 ft is the elevation correct, not the DA? I guess it just seemed high to me. But then, Hawaii is just a big volcano anyways.
Aug 12, 2003 | 01:05 AM
Hmm. I'm showing a DA of 2200... assuming a 50% humidity.
But the correction factor is .987.... so, corrected rwhp = 395
If the DA is zero, the RWHP should be 1.00000 right? My equations must be flawed, i'll have to go back and double check.
That DA is correct though. The elevation isn't taken into account because it affects baro pressure which is already being measured.
