Did you Pre-Order a Dynaspark from DynoTech ?
Old Aug 14, 2003 | 06:53 AM
luvmy92's Avatar
luvmy92
Default Re: Did you Pre-Order a Dynaspark from DynoTech ? (Lone Ranger)
You can wash w/ water now w/ OEM opti. I have. But. Here's my method I use:
1. stuff rags all around the top and sides of opti wherever you can stuff them
2. No sprayer on hose-- open ended garden hose, spigot on 1/3 or less (up to 1/2 dependent on local water pressure).
3. Mist down bay w/ something like Simple Green or (better) Greased Lightening Orange Blast.
4. Toothbrush or other device where needed.
5. rinse gently w/ hose setup per #2, taking care to not put water near opti.
6. Sop up any pools of water laying on intake, valve cover valleys, etc.
7. Drive for an hour or so to evaporate off any remaining water.
That's how I did it anyhow...
:iagree:
That's exactly how I wash mine as well. I do mine after every racing event plus a few other times during the course of a year. No problems so far...
Mike
Old Aug 14, 2003 | 08:20 AM
DTE Powertrain's Avatar
DTE Powertrain
Collections Hold
Default Re: Did you Pre-Order a Dynaspark from DynoTech ? (luvmy92)
Good morning Tom-
Yes, Ramrod is correct. You dis-engage the grey/black four pin female connector from your existing harness and re-use it on the Dynaspark harness. We supply a small tool in our kit that facilitates the easy removal of the existing harness pins and the instructions provided are very intuitive. The same procedure applies for all years and models of LT1/LT4 engines. :)
Regards,
Phil
Old Aug 14, 2003 | 05:54 PM
grapeknutz's Avatar
grapeknutz
St. Jude Donor '06
Default Re: Did you Pre-Order a Dynaspark from DynoTech ? (Da Wiz)
Hey Phil whats your time line if I were to place an order today I been waiting for the official "roll out" for some time.
Old Aug 14, 2003 | 07:45 PM
DTE Powertrain
Collections Hold
Default Re: Did you Pre-Order a Dynaspark from DynoTech ? (grapeknutz)
Model? Car? Year?
Regards,
Phil
Old Aug 14, 2003 | 08:28 PM
grapeknutz's Avatar
grapeknutz
St. Jude Donor '06
Default Re: Did you Pre-Order a Dynaspark from DynoTech ? (DynoTech Engineering)
Sorry 92 LT1 vette....thanks
Old Aug 15, 2003 | 10:58 AM
DTE Powertrain
Collections Hold
Based on our current backlog of Gen I's and anticipated shipment of those units, a safe estimation for new order shipment should be the first portion of the second week of Sept. :)
Regards,
Phil- DTE
Old Aug 15, 2003 | 04:26 PM
camarolt1's Avatar
camarolt1
I ordered back in June, also.
For GEN I, does the the cam-to-dynaspark keyed rod require an O-ring at both ends?
:cool:
Old Aug 15, 2003 | 06:03 PM
DTE Powertrain
Collections Hold
Default Re: Did you Pre-Order a Dynaspark from DynoTech ? (camarolt1)
The O.E. splined shaft that is used with the original Optispark distributor is discarded because that shaft is now integral to the Gen I Dynaspark and it engages into the camshaft gear the same as O.E. on the camshaft side. This eliminates the need fpr one complete seal and possible source for moisture intrusion.
Regards,
Phil
Old Aug 16, 2003 | 03:15 PM
camarolt1's Avatar
camarolt1
The last 2 optis I bought from Pep Boys and Autozone used a Mitsubishi reader, which actually failed on my second one. Is your reader GM OE or Mitsubishi or something better?
In the unlikely chance that something breaks in the future (over 1 year), will you have a replacement piece price sheet?
Thanks again
[Modified by camarolt1, 10:31 PM 8/16/2003]
[Modified by camarolt1, 1:58 PM 8/17/2003]
Old Aug 16, 2003 | 05:48 PM
DTE Powertrain
Collections Hold
Look more closely at the rebuilders "re-manufactured" optical sensor and you will soon see that they are NOT new replacements in those rebuilt units....
Those reman companies put the sensors through an oversimplified electrical function test and cleaning cycle and then simply put them back into use. That is why one can get one of those units so cheaply, but you end up replacing it again and again. You certainly get what you pay for......
We use brand new sensors from Mitsubishi in every one of our units, not refurbished, worn-out sensors like some do. That is why our product carries with it the cost, but you also get an excellent performing ignition system that is also moisture tight. We already have a few of these things operating successfully in the NHRA Stock Eliminator Class where they are going through the traps at 7000+ engine RPM. Once again, you get what you pay for....... :)
Regards,
Phil
Old Aug 17, 2003 | 09:04 PM
Da Wiz's Avatar
Da Wiz
Ahh Phil,
Suddenly I feel so wise for leaving my Vette on jackstands, awaiting delivery of my Dynaspark. Now, if I can just get the valve train to hold together at 7k.... :eek: :D :flag
Old Aug 19, 2003 | 04:39 PM
camarolt1's Avatar
camarolt1
I'm not sure why it would, but does an MSD 6A ignition harm the dynaspark in any way?
:chevy :flag
Old Aug 19, 2003 | 05:28 PM
  #33
ered95's Avatar
ered95
What is the cost for a 95? :cheers:
Old Aug 19, 2003 | 05:58 PM
  #34
DTE Powertrain
Collections Hold
Default Re: Did you Pre-Order a Dynaspark from DynoTech ? (ered95)
Multiple spark delivery ignition systems will not adversely effect our product and the cost for all models and years is $599 + S&H.
Regards,
Phil
Old Aug 19, 2003 | 06:05 PM
  #35
Strick's Avatar
Strick
Hi Phil,
I wish you had your Dynaspark available when I did my opti replacement. Do I understand that your Dynaspark can withstand an engine washing? I guess I'll keep your number/web site for my future upgrade. Oh, one more thing, I vented my 92 opti, does your Dyna spark for my year have venting?
Old Aug 19, 2003 | 07:45 PM
  #36
DTE Powertrain
Collections Hold
Default Re: Did you Pre-Order a Dynaspark from DynoTech ? (Strick)
Some of the more FAQ can be answered here on our website. :)
http://www.dynotech-eng.com/dynaspark.htm
Regards,
Phil
Old Aug 27, 2003 | 11:24 AM
  #37
Da Wiz's Avatar
Da Wiz
Hi Phil,
Wanted to check in and see how the splined shaft delivery was going. Hope all is well.
Standing by, looking for the Post man !! :sad:
To Did you Pre-Order a Dynaspark from DynoTech ?
Old Aug 27, 2003 | 06:43 PM
  #38
DTE Powertrain
Collections Hold
We have taken delivery of the remainder of our order for the Gen I splined drive shafts this afternoon and starting tomorrow, we will start filling the waiting orders for the Gen I Dynaspark Distributors. We're working through the holiday weekend, so we should be completely caught up w/ the Gen I orders by Wednesday of next week and then we will be stocking these on our shelves for immediate delivery for future orders. :hurray:
Regards,
DTE
Old Aug 27, 2003 | 10:33 PM
  #39
Strick's Avatar
Strick
Woo Hoo :hurray: :party: This is good news for us guys that want to change over, but don't have to yet. Saw one guy had a problem with one of your Dyna-sparks. Let us know if any trends develope. Sorry to hear you have to work over the big weekend, but it's good to hear you are back on track. Good luck
Old Aug 28, 2003 | 07:15 AM
  #40
Da Wiz's Avatar
Da Wiz
And a Roar goes through the crowd :D :cheers: :flag
