just pulled my codes and.......
Old Aug 12, 2003 | 06:17 PM
Cory00's Avatar
Cory00
Default just pulled my codes and.......
just got back from auto zone and they pulled my codes fine and the codes were
14
and 44
the guy told me 14 was my coolant temp sensor and 44 was my o2 sensor
is this right :confused:
if so how do i go about fixing the probs.
any help would be great :cheers:
Old Aug 12, 2003 | 06:24 PM
SkunkCar's Avatar
SkunkCar
Default Re: just pulled my codes and....... (Cory00)
Here's a guide to determining codes...
http://www.corvettedoctor.com/Codes_Page.htm
Old Aug 12, 2003 | 06:27 PM
offershore's Avatar
offershore
14 is high coolant temp. check your cooling sys. replace the o2 sensor
Old Aug 12, 2003 | 06:28 PM
Cory00's Avatar
Cory00
Default Re: just pulled my codes and....... (offershore)
if 14 means i have a high coolant temp then i must be overheating at 200 -210 ish :confused: :confused: should that be like that
Old Aug 12, 2003 | 06:35 PM
Cory00's Avatar
Cory00
Default Re: just pulled my codes and....... (Oldman)
thanks
:cheers:
i think im going to take it to a shop soon to get it looked at :confused:
thanks for all the help
Old Aug 12, 2003 | 06:36 PM
offershore's Avatar
offershore
Your car is probably running lean due to a bad 02 and that will trigger high temp.
Old Aug 12, 2003 | 06:38 PM
Southern Comfort's Avatar
Southern Comfort
:iagree: O2 is $35-50 bucks depending on where you get it. Changed mine about a month ago and it made a big difference on overall performance. :thumbs:
Old Aug 12, 2003 | 06:39 PM
SkunkCar's Avatar
SkunkCar
If this is the case, changing the O2 sensor is easy from what I understand. Haven't done it myself, though. If I were you, I'd dig in and change the sensor yourself ... you'll save some bucks and learn something new :thumbs:
Old Aug 12, 2003 | 06:40 PM
offershore's Avatar
offershore
Default Re: just pulled my codes and....... (SkunkCar)
:iagree:
After you change it, disconnect the batt. for 5 min. then take it out for for a ride min. 1/2 hour you should se a huge diff. and hopefully no new codes. :thumbs:
[Modified by offershore, 11:47 PM 8/12/2003]
Old Aug 12, 2003 | 06:41 PM
Cory00's Avatar
Cory00
yea ive already looked on ecklers o2 sensor 37 and the coolant sensor 36
i think i might break open my haynes book and see if i cant do it my self
like a weekend project :cool:
thanks
Old Aug 12, 2003 | 06:44 PM
04Z16's Avatar
04Z16
CI 3-4-5-6-7-8-9-10 Veteran
Just changed all four on mine because I pulled a code. It took about 35 minutes but I had access to a lift. They are not that hard to change even if you have to do it in the driveway or garage. Good Luck.
:cheers:
Old Aug 12, 2003 | 06:58 PM
Cory00's Avatar
Cory00
Default Re: just pulled my codes and....... (GS487)
thanks for all the help :cheers:
but i have one more ?
should i get this done soon or will it be ok to put off for a little while :confused:
thanks agin for all the help
Old Aug 12, 2003 | 07:02 PM
offershore's Avatar
offershore
you can put it off but why. it will pay for itself in no time your gas milage must be way off not to mention the power loss. DO IT! you cheap O (kidding)
To just pulled my codes and.......
