Fuel Injector Cleaner. Chevron Safe??
Old Aug 12, 2003 | 07:32 PM
JB666's Avatar
JB666
Default Fuel Injector Cleaner. Chevron Safe??
I've been reading through the archives, and see some people using fuel injector cleaner as often as every other fillup. Now, is this necessary??? Also, I have only been driving my car for about 5 months now, but have never run any cleaner through.. I figured it's probably about time with the crap gas in our area... Is Chevron safe for the injectors??? Thanks, in advance :cheers:
Old Aug 12, 2003 | 07:42 PM
Southern Comfort's Avatar
Southern Comfort
Default Re: Fuel Injector Cleaner. Chevron Safe?? (Jbaker)
I have heard mixed feelings about this. I use Valvoline SynPower now and then. No regular schedule but whenever I get the urge.
Some on here reccomend NO injector cleaner.
I guess its just a matter of opinion. :seeya
Old Aug 12, 2003 | 07:55 PM
vader86's Avatar
vader86
I use one about twice a year, sometimes i think i notice a slight change in performance for the better
the Chevron/Techron stuff would be the only one i use tho
Old Aug 12, 2003 | 08:01 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
Default Re: Fuel Injector Cleaner. Chevron Safe?? (vader86)
GM specifically recommends against it..having said that my mechanic told me if I just have to put some in to use Chevron's...I broke down and put one bottle in about 18 months ago...nothing since...good luck
Old Aug 12, 2003 | 08:07 PM
larrybsp's Avatar
larrybsp
Since GM switched to the Rochester injectors with the ball seats instead of the Bosch injectors with pintles ther is no need for an injector cleaner (Re GM).
For the recoed, Chevron high test gas has Techron cleaner in it so if you use the gas you don't need the additive. :seeya :seeya :seeya
Old Aug 12, 2003 | 08:17 PM
JB666's Avatar
JB666
Default Re: Fuel Injector Cleaner. Chevron Safe?? (larrybsp)
Well, my local dealer is the one who recommended Chevron, but, after reading here, I was stuck somewhere in the middle. My '95 doesn't always feel like it has the power that it should.. Then again, I've still yet to feel full throttle!!! Just that it feels kind of sluggish out of the hole some times........
Old Aug 13, 2003 | 02:29 AM
skeet's Avatar
skeet
I have heard that both octane boosters and injector cleaners are corrosive. If i were to use them I would try to use the tankful of gas in one day and not let it sit for days or weeks so it would not have time to corrode parts.. Not good for injector windings, rubber gaskets in fuel pump, etc. Some cleaners say on the bottle to change the oil after using their product so wait for the next oil change and use it right before. Guess some of the corrosive chemicals get into the oil plus what ever crap it cleans out of the cylinder/injectors gets into the oil.
Old Aug 13, 2003 | 08:53 AM
sraft's Avatar
sraft
Default Re: Fuel Injector Cleaner. Chevron Safe?? (skeet)
I've read (or heard) that the Multec injectors used on the LT1s flow gas over the injector coil to cool it. I believe that this is why they recommend agaist any solvent based cleaners - if the cleaner degrades the insulation on the winding it'll ruin the injector.
To Fuel Injector Cleaner. Chevron Safe??
