Why would my differential be hot?
Old Aug 13, 2003 | 09:00 PM
Chatman's Avatar
Chatman
Default Why would my differential be hot?
I just came in from checking to see whether I had a 36 or 44. I have a 36. I discovered that the differential was hot. :reddevil How hot? Hot enough that the plastic tag at the fill hole has deformed and the pumpkin was hot to the touch an hour after driving. It's either friction or exhaust right?
There is space between the exhaust and the pumpkin (an inch?) but no heat shield. If internal friction, then is there anything to do? I did refill the diff a few months ago when I bought the car (GM products) and I believe that I got the mix right. I do recall that what came out was black but assumed that was normal for a Corvette.
How much space should there be between the pipe and pumpkin? Should there be a shield? Anyway to determine the cause of the problem.
Thanks in advance.
Old Aug 13, 2003 | 09:04 PM
froggy47's Avatar
froggy47
Default Re: Why would my differential be hot? (Chatman)
That seems too hot, don't have an answer, sorry.
Old Aug 13, 2003 | 09:23 PM
jfb's Avatar
jfb
Differentials get hot. Best check to see if you have the correct level of diff lube in yours.
Old Aug 13, 2003 | 09:57 PM
lead foot 85 vet's Avatar
lead foot 85 vet
Default Re: Why would my differential be hot? (jfb)
the nascar boys have a cooling system for differential oil because of the heat . :yesnod:
Old Aug 16, 2003 | 12:52 PM
Chatman's Avatar
Chatman
I have the answer. There was an exhaust leak that caused the plastic tab to deform / melt. I went ahead and replaced the oil w/additive just in case and the oil coming out looked OK. Good news. Well, the leak isn't such good news but that is a much cheaper fix than a fried pumpkin. :chevy
[Modified by Chatman, 5:53 PM 8/16/2003]
Old Aug 16, 2003 | 12:57 PM
mitchcole's Avatar
mitchcole
Take it for another ride - It's likely that it will be just as hot as before.
I had a GMC 1500 truck with a 3/4 ton rear end that also got hot. I would use it towing and that's just the way it works. GM recommended synthetic rear end oil on towing applications.
Of course the vette weighs about 1/3 as much... Just keep an eye on it.
To Why would my differential be hot?
