domed or flat pistons?
Old Aug 15, 2003 | 03:33 AM
aussie 84vette's Avatar
aussie 84vette
Default domed or flat pistons?
how much extra performance would you get from dome pistons as opposed to flat?
im getting my engine re-built cause im gettin a little oil on one of my spark plugs..
thanks
Old Aug 15, 2003 | 05:33 PM
offershore's Avatar
offershore
Default Re: domed or flat pistons? (aussie 84vette)
It's not that simple.
Old Aug 15, 2003 | 06:03 PM
vader86's Avatar
vader86
piston choice depends on the compression ratio you want/need for optimum power
just changing your pistons on an 84 wont do anything but force you to use expensive gasoline
Old Aug 16, 2003 | 01:51 AM
aussie 84vette
Default Re: domed or flat pistons? (vader86)
cool thanks vader :)
Old Aug 16, 2003 | 12:47 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
Wrong. It will increase compression ratio which will increase horsepower. But then you have to make sure you don't get spark knock, causing the ECM to take out timing which puts you back where you started in the first place.
Old Aug 16, 2003 | 01:24 PM
offershore's Avatar
offershore
Default Re: domed or flat pistons? (flyersfan1088)
[QUOTE]just changing your pistons on an 84 wont do anything but force you to use expensive gasoline
Wrong. It will increase compression ratio which will increase horsepower. But then you have to make sure you don't get spark knock, causing the ECM to take out timing which puts you back where you started in the first place.[/QUOTE
:iagree: Thanks. I didn't wan't to start. :crazy:
[Modified by offershore, 6:25 PM 8/16/2003]
Old Aug 16, 2003 | 02:47 PM
C10 JDR's Avatar
C10 JDR
Default Re: domed or flat pistons? (offershore)
Then theres the matter of quench. But I don't want to get into that either.
Flat is best. :D
[Modified by britvette, 8:45 PM 8/17/2003]
Old Aug 19, 2003 | 04:41 AM
aussie 84vette
yeah sounds abit complicated i might just leave them how they are.. thanks guys
Old Aug 19, 2003 | 08:23 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
I would leave them flat, and build the compression up with the heads. Shave them a little.
:cheers:
To domed or flat pistons?
