Source for Optispark Gaskets?
Old Aug 15, 2003 | 10:37 AM
Da Wiz's Avatar
Da Wiz
Default Source for Optispark Gaskets?
I took mine apart last night, since I am waiting on a new Dynaspark. It was running fine before the removal, but I noticed a small water leak from the pump during the disassembly. This unit is perfect inside!! No corrosion at all on the optical disk or internals.
The gaskets inside had a couple of cracks on the side, but for the most part look to have been preserved by a small oil leak I found at the timing cover / oil pan junction. I would like to replace these gaskets and re-install the opti while waiting for the new Dynaspark. Anybody done this, and where did you find the gaskets?
Thanks in advance,
:cheers: :flag :cheers:
Old Aug 15, 2003 | 11:18 AM
bogus's Avatar
bogus
Default Re: Source for Optispark Gaskets? (Da Wiz)
screw the gaskets... use RTV.
Old Aug 15, 2003 | 11:28 AM
Da Wiz's Avatar
Da Wiz
Default Re: Source for Optispark Gaskets? (bogus)
Simple...elegant...effective...I like the way you think.... :cheers:
To Source for Optispark Gaskets?
