85 acts "flooded"
Old Aug 15, 2003 | 07:37 PM
dajod's Avatar
dajod
7th Gear
Default 85 acts "flooded"
85 L98 cranks and cranks and finally starts with a lot of black smoke. Idles and runs fine after starting. Does this hot or cold. I suspect stuck cold start valve. Any other ideas? Is this a job a weekend mechanic can tackle?
Old Aug 15, 2003 | 08:03 PM
Corvette0096's Avatar
Corvette0096
Default Re: 85 acts "flooded" (dajod)
Welcome to the fourm.. I would guess your TPS is bad.
Old Aug 15, 2003 | 08:05 PM
NHVett's Avatar
NHVett
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: 85 acts "flooded" (Corvette0096)
:iagree:
Old Aug 15, 2003 | 08:37 PM
Frizlefrak's Avatar
Frizlefrak
:iagree:
Welcome.....Are you getting a check engine light? TPS sounds like the first place to start looking...
Old Aug 16, 2003 | 01:47 AM
dajod's Avatar
dajod
7th Gear
Default Re: 85 acts "flooded" (Frizlefrak)
No Check Engine Light before. Changed TPS; can only get voltage adjusted to .67 instead of .54 volts. Now I'm getting Check Engine Light. Too late here to continue work; will resume tomorrow.
Old Aug 16, 2003 | 05:56 AM
MtlSphere's Avatar
MtlSphere
.54v is optimum TPS specs with a tolerance of .075+/-, so .62 is the max closed voltage.
If you can't adjust the TPS far enough to get inside that window take a small round file (available just about anywhere tools are sold) or a 5/16 drill bit and open up mounting screw holes in the switch. Make sure there are no obstructions when mounting the switch to the TB and that the pick-up lever is mated to the throttle lever flush.
Have fun! :seeya
To 85 acts "flooded"
