Engine Ticking?
Old Aug 15, 2003 | 09:45 PM
CENTURION's Avatar
CENTURION
Default Engine Ticking?
My 1988 has a ticking noise on the drivers side of the engine, any ideas on the cause. Seems to still run good and pull hard (has 53K miles). I'm thinking maybe a stuck lifter, or bent pushrod, or perhaps the rockers need adjustment?
Thanks.
Old Aug 15, 2003 | 09:49 PM
92corvette's Avatar
92corvette
Default Re: Engine Ticking? (CENTURION)
The injectors on all of these cars make a clicking sound.
Maybe?
Old Aug 15, 2003 | 09:56 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Check out your injectors. Maybe run a cleaner thru them. Every other tank full I put in some "OUTLAW" injector cleaner.
This has helped.
I think this would help.
tony
:chevy :chevy
[Modified by oldace84, 6:58 PM 8/15/2003]
Old Aug 16, 2003 | 12:56 AM
JCAIRE2's Avatar
JCAIRE2
Get a mechanics stethescope from sears or local partshouse. Isolate the ticking sound and tell us where it's coming from. :cheers:
Old Aug 16, 2003 | 06:27 AM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
Default Re: Engine Ticking? (JCAIRE2)
Mine does the same...a little annoying....bu I believe it's the injectors also.
Old Aug 16, 2003 | 08:14 AM
89CONV's Avatar
89CONV
First check the injectors, and second check your oil level (sounds silly but true). A quick fix for noisey lifters is MOLY E engine additive which will quiet down the lifters. I used this stuff for two years on my last car and it worked every oil change.
:cheers:
Old Aug 16, 2003 | 10:30 PM
CENTURION's Avatar
CENTURION
Default Re: Engine Ticking? (89CONV)
Thanks for the replies, I had the injectors pressure tested and they were not leaking. I had a Chevy truck that did this and I ran a quart or tranny fluid in the oil before changing and it quieted them down great. On my 79 Firebird the culprit was a broken pushrod guide plate. Seems to do it after she's warmed up.
Old Aug 16, 2003 | 11:00 PM
Tourney3p0's Avatar
Tourney3p0
I did the same thing to my 81 Firebird. I never had to worry about it being noisy again.. the new motor I had to drop in it is very quiet in comparison! :D The previous owner ran it about 10k miles on Quaker State with no oil change.
Seriously though, I have a slight ticking sound as well and it's injectors for me. I was sure that it was below the valve cover, but when I popped mine off there was nothing out of the ordinary going on under there, and it quieted down when I put new injectors in.
Old Aug 17, 2003 | 12:13 AM
CENTURION's Avatar
CENTURION
Default Re: Engine Ticking? (Tourney3p0)
Tourney3p0,
Is it the pulsing (or sticking) of the injectors making the sound?, what replacements did you do ? and what was the cost.
Thanks.
Old Aug 17, 2003 | 12:26 AM
Tourney3p0's Avatar
Tourney3p0
I didn't replace mine because the ticking.. from what I've gathered here on the forum, it's normal. I replaced mine because I had some that were stuck open and I lost 35 pounds of pressure in about 5 minutes.
Try touching your finger to one of your injectors and see if the pulsing from the injector (trust me, you'll feel it) coincides with the ticking you hear. You shouldn't have to remove anything to test it. Just open the hood and touch the side of the injector.
Old Aug 17, 2003 | 01:05 AM
CENTURION's Avatar
CENTURION
Tourney3p0,
Cool tip, I'll try it. I planned on new injectors for next year if I still have this car, I keep getting tempted on newer vette's, because the prices on the C-5's in this area are getting real low due to the current economic conditions. I spotted a '00 with 15K miles for $23K, heck you can hardly get a Korean mini SUV for that price.
To Engine Ticking?
