the Accel SuperRam EFI SBC Intake kit. heres the specs.
This kit includes almost everything you need to retrofit the hottest EFI system today into your street car. This system uses a tuned plenum/runner combination that provides balanced air flow to each cylinder. The SuperRam is only 9 3/8" tall to fit under almost any hood. Components are available separately, however, for retrofit applications where you will need all of the components, this kit is a much better buy than purchasing each item separately.
Included in the kit: intake manifold, 58 mm billet throttle body, Accel Gen VII ECU, wiring harness, fuel pump, injectors, fuel rail, sensors, fittings, gaskets & instructions.
These systems are pre-calibrated from the factory but will require custom tuning after installation. Calibrations can be done via an IBM compatible PC computer using Calmap software. Polishing of external surfaces not included.
I was wondering why it was so much! thanks for clearing that up. since it's alot cheaper than i thought I should possibly have that done by the end of the year. right now I have to get interior and weatherstripping :(
