I need the part # for the above for a C68 equipped '87. I can't find the part # anywhere and I used to have it. This is NOT the blower motor control resistor, that is the for the non-C68 cars.
Re: Part #? Blower Motor Control Module (scorp508)
Ok I found a post on the net from a guy with a Cadillac who needed one and GM said it was discontinued. He finally found 12484912 as a replacement. gmpartsdirect shows nothing for my P/N but does show that replacement one for $156 at GM List and $78 their cost as "module". Ugh. The last time I ordered from them the experience was horrible and I told them I'd never order from them again.
Re: Part #? Blower Motor Control Module (vetracer)
If you don't mind my asking, what does this part do? :lurk:
Controls the blower fan speed in a Electric C68 HVAC car. Mine is semi-gone and at times allows the blower fan to run when the car is OFF. Its no fun going to the car only to find a dead battery if I didn't unplug the blower fan. :(
Thanks for the reply, Scorp. I've been having a problem with my climate control fan speed slowing down/speeding up for no apparent reason. It's usually over 105 degrees here this time of year and when I set it at 60 degrees it should be blowing as hard as it can all the time because you can't get the inside temp anywhere near that cold on a hot day when the car has been sitting in the sun. Maybe this part is causing the problem... Hmmm...
Could also be your temp sensor located above the driver's head in the rollbar. There is a small grate with a sensor behind it that monitors cabin temp.
