Locked keys in my 85 HELP!
Old Aug 16, 2003 | 01:21 PM
montie98's Avatar
montie98
Default Locked keys in my 85 HELP!
Does anyone know a trick to get in?
Old Aug 16, 2003 | 01:34 PM
vader86's Avatar
vader86
Default Re: Locked keys in my 85 HELP! (montie98)
yeah, call the locksmith
Old Aug 16, 2003 | 04:34 PM
montie98's Avatar
montie98
Default Re: Locked keys in my 85 HELP! (vader86)
Thanks for the tip Vader! The locksmith just left my house
Old Aug 16, 2003 | 04:45 PM
JCAIRE2's Avatar
JCAIRE2
Next time, if you can pull the window away from the weatherstripping slightly, you can stick a hanger, or something similar through the gap and hit the power lock button. Cheaper than a locksmith. :cheers:
Old Aug 16, 2003 | 05:40 PM
McShagger's Avatar
McShagger
Default Re: Locked keys in my 85 HELP! (JCAIRE2)
I did that once... Luckly, the customer I was at was a mechanics shop with lots of guys that probably broke into cars for secondary income... :p: Anyways, they had a slim jim and tried for a long time to get in... after a while one of the guys exclaimed, "Man, your car is hard to break into." We went about it thru the window and hit the power lock switch. :p:
Old Aug 16, 2003 | 08:07 PM
C10 JDR's Avatar
C10 JDR
Default Re: Locked keys in my 85 HELP! (McShagger)
I did this, in one of my more intelligent moments. Door locked, engine running, headlights and windscreen wipers on. Raining.
I found a long strip of steel, threaded it over the top of the windoew, and nudged the window lift/lower switch on the console, 'til I could get my hand in top open the door.
Old Aug 16, 2003 | 10:23 PM
jfb's Avatar
jfb
Yes, here is the trick, it works every time. Grasp your wallet, retract it from where you keep it (mine is in my left rear pant pocket), open the wallet and extract the door key, open the car door with the spare door key and you will then have access to your ignition key which is still in the ignition switch. :D
Old Aug 17, 2003 | 02:33 AM
drvette85's Avatar
drvette85
Default Re: Locked keys in my 85 HELP! (jfb)
:lolg: :lolg: :lolg: :lolg: :lolg:
:iagree:
Old Aug 17, 2003 | 04:06 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Gotta admit, I keep a spare door key in my wallet as well. Many if not most wallets have a location just for this. Never had to use it in anger, but nice to know it's there.
Old Aug 17, 2003 | 07:41 AM
Sam Lam's Avatar
Sam Lam
Default Re: Locked keys in my 85 HELP! (Ray Quayle)
I know this idea is of little or not value to the original post, but this is a place to share ideas. I have locked myself out of the car several times and finally decided to do something about it! I keep a spare DOOR KEY in a magnetic key holder and this is "stuck" under the car where I can get to it. This has come in handy during some of my dumb azz moments! The little plastic boxes are readily available from Wal Mart for less than a dollar.
Old Aug 17, 2003 | 02:09 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: Locked keys in my 85 HELP! (Sam Lam)
Keep a spare door key in your wallet....
keep a spare ignition key hidden INside the vette...
I only made that mistake once!
Old Aug 17, 2003 | 10:40 PM
corvettemaster's Avatar
corvettemaster
:iagree: i've always done this. works real well :lol:
To Locked keys in my 85 HELP!
