Wiper problem, Question
Old Aug 16, 2003 | 03:03 PM
HG's Avatar
HG
Default Wiper problem, Question
Wipers run normally at times, then, won’t run except on high. Also, won’t park for a couple of minutes after turning off. I don’t fee it’s the motor or the door switch. I think it is in the park switch in the wiper motor. If I giggle the connector at the motor, it starts to work. Connection is clean and OK How hard is it to get the switch out of the motor? :crazy:
Old Aug 16, 2003 | 03:49 PM
Mrcorvette91's Avatar
Mrcorvette91
Default Re: Wiper problem, Question (HG)
It is not that difficult at all. I had similar problems, but it ended up being the motor itself. I figured this out after I took the motor off, exchanged the park switch, put it all bcak together and back into the Vette...*LOL* Seriously, it is no problem at all. the most difficult part of all is getting to the motor to remove it from the Vette. On a scale of 1-10, I would rate changing the plugs a 7...working on the wiper motor, about a 2. Good luck! :chevy
Old Aug 16, 2003 | 04:21 PM
HG's Avatar
HG
Default Re: Wiper problem, Question (Mrcorvette91)
Hey, thanks. do you have to remove the motor to pull out the park switch?? :withstupid:
[Modified by HG, 4:22 PM 8/16/2003]
Old Aug 16, 2003 | 06:19 PM
BlackbirdZ07's Avatar
BlackbirdZ07
No, you don't have to remove the wiper motor from the car to replace the park switch. You can get to it easily by removing the black plastic cover from the wiper motor. When you remove the old park switch, make sure to look to see how everything goes together. It took me a little while to figure out how it fits into the motor.
Old Aug 17, 2003 | 08:13 PM
HG's Avatar
HG
OK, thanks. With my luck, I'll probably drop something and never get it together. :withstupid:
To Wiper problem, Question
