Replace rear bulbs
Old Aug 17, 2003 | 04:03 PM
bojangles's Avatar
bojangles
Default Replace rear bulbs
I've run a search but 'no information' available. How do you replace
the driver side rear blinker bulb.. I have taken the license fram off
but my are is to large to fit in. Which way do you turn to bulb socket?
Is there an easier way?
Thanks your your help..
Old Aug 17, 2003 | 06:32 PM
bojangles's Avatar
bojangles
Default Re: Replace rear bulbs (Oldman)
No,,,, I'm replacing the blinker bulb on a friends C4. In a C5 it is a
'piece of cake'...
Old Aug 17, 2003 | 06:33 PM
scorp508's Avatar
scorp508
Default Re: Replace rear bulbs (cares)
Remove the license plate, remove the reverse bulb housing and go at it. Some people have been able to snake their arms up from beneath past the mufflers.
Old Aug 18, 2003 | 07:25 AM
Red Tornado's Avatar
Red Tornado
Default Re: Replace rear bulbs (scorp508)
:iagree: In my case the license plate path was much easier :yesnod:
Old Aug 18, 2003 | 12:55 PM
BILLYD's Avatar
BILLYD
Default Re: Replace rear bulbs (bradvette)
theres a little tab on the light socket that needs to be pushed in before turning the socket
To Replace rear bulbs
