LT1 stumbles under high load
Old Aug 18, 2003 | 08:04 AM
rmd8136's Avatar
rmd8136
Default LT1 stumbles under high load
My '95 LT1 stumbles under high load (full throttle) usually in the 4600 to 5500 rpm range. There is also a lean popping noise in the exhaust (light backfire). All other engine performance is normal. Problem is only at full throttle. I have repalced the fuel pump and strainer and it did not fix the proble. It seems like a fuel delivery problem. I am replacing the fuel filter next. I measured fuel system pressure at the schrader valve on fuel inlet pipe and it's about 45 psig and drops to about 42 when stumbling occurs. Any suggestions on problem?
Old Aug 18, 2003 | 08:26 AM
jfb's Avatar
jfb
Default Re: LT1 stumbles under high load (rmd8136)
Plugs not firing. Check the resistance of the plug wires, they should measure about 5000 ohms per foot. If you have plugs with a lot of miles on them, install new ones.
Old Aug 18, 2003 | 08:36 AM
bogus's Avatar
bogus
opti = :U
Old Aug 18, 2003 | 09:42 AM
sraft's Avatar
sraft
Default Re: LT1 stumbles under high load (bogus)
opti = :U
:iagree: Misfiring under load and at high rpm is a classic opti failure symptom.
Old Aug 18, 2003 | 09:58 AM
rmd8136's Avatar
rmd8136
What is an OPTI failure symptom?
Old Aug 18, 2003 | 10:53 AM
bogus's Avatar
bogus
check for stored code 16. that is the low res signal getting all jiggy.
high rpm stumble and pops... that about sums it up.
oh, hunting idle.
Old Aug 18, 2003 | 10:56 AM
rmd8136's Avatar
rmd8136
How do I fix it?
Old Aug 18, 2003 | 11:28 AM
vvv90's Avatar
vvv90
How do I fix it?
IM me your email and I'll give you my opti replacement guide.
Also, before you replace your opti, do plugs, wires, and do more research before you do the opti because it's a big job.
Old Aug 18, 2003 | 12:14 PM
rmd8136's Avatar
rmd8136
Default Re: LT1 stumbles under high load (vvv90)
My e-mail is RMDICKSO@DUKE-ENERGY.com
What is OPTI?
Old Aug 18, 2003 | 01:00 PM
bogus's Avatar
bogus
Opti-Spark.
It is the distributor... GM put it on the front of the engine... below and kinda under the waterpump, and above and behind the harmonic balancer.
if water is not its friend, antifreeze is it's enemy.
they get wet inside, it builds up, causes carbon tracing and eats bearings.
not good.
they cost upwards of 1200.00 if you have a dealer do it!!! 1/2 that if you do it... the job is not hard, just time consuming.
Old Aug 18, 2003 | 03:45 PM
vvv90's Avatar
vvv90
More like 1/3 of the price--$350 to do it yourself.
Old Aug 18, 2003 | 04:26 PM
DougSilver's Avatar
DougSilver
Could be opti and/or wires and/or plugs. I have a 95 and had similar symptoms--hesitating under load and also stumbling at idle when AC switched on. Dealer replaced opti and symptoms were initially gone but then came back almost worse than before. Brought the car back and replaced opti again but the mechanic also noted that the opti failure (first time?) had caused faulting of the spark plugs and wires, so those were replaced also (all this was essentially no-cost due to the 7-year 70,000 mile emissions warranty that some states have). Since that time (June 2002) car has been fine.
By the way, as poorly as the car was running during these times, no codes were ever registered by the onboard computer.
Old Aug 18, 2003 | 05:34 PM
LT4POWR's Avatar
LT4POWR
Check/replace all your plugs & plug wires. Also, check/replace the coil & coil wire.
Old Aug 18, 2003 | 06:52 PM
bstirn's Avatar
bstirn
Default Re: LT1 stumbles under high load (LT4POWR)
I have the same problem with my 92. I have the hole unit being replaced with plugs and wires next tuesday. :chevy
Old Aug 18, 2003 | 07:17 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: LT1 stumbles under high load (bstirn)
Yes, like stated above, check the coil wire, it has a tendency to rub against the water pump, that happened to me with my '95.
The '95 has a vented opti, so moisture shouldn't be a factor unless it got soaked.
My '93, the symptoms were just as you described, I went ahead and left the old opti in, but bypassed the high voltage part and converted to the LS1 coil setup.
Cost is a little more than a standard opti replacement(opti=$400+$300 labor).
But I'll never have to worry about it again.
See my post here:
http://forums.corvetteforum.com/zerothread?id=629638
Old Aug 19, 2003 | 06:34 AM
Atok's Avatar
Atok
Default Re: LT1 stumbles under high load (jfb)
:iagree:
My '95 had the same problem. People here said the usual...Opti. Turned out to be spark plugs. Follow the diagnostic procedure in the Service Manual. Check your plugs first, then wires, coil, etc.
Old Aug 19, 2003 | 09:44 AM
QuikZilver's Avatar
QuikZilver
Default Re: LT1 stumbles under high load (Atok)
I recently was having the same type of problem. I know the optispark is good, as it is only around 25,000 miles old, if that. I do know that the plugs and wires need to be replaced and have them on order. My hesitation ended up being the throttle position sensor. Under a full load, the TPS was not acting right. I replaced the sensor and the stumbling went away. It was only happening when my Vette was around 215 degrees or hotter. At cooler temps, it didn't stumble at all. May want to take a look at your TPS. It is a heck of a lot cheaper! And could be the source of your problem as well.
:seeya
Old Aug 19, 2003 | 11:31 AM
DougSilver's Avatar
DougSilver
Default Re: LT1 stumbles under high load (Whitvette)
One significant clue that helped the mechanic to identify my problem was that I could get the "miss" to occur at idle by just switching on the AC. It seems that the added load on the engine was enough to cause the faulty ignition components to break down.
To LT1 stumbles under high load
