a/c oil
Old Aug 18, 2003 | 03:26 PM
jtfrog's Avatar
jtfrog
Default a/c oil
Is it ok to mix pag oil with ehster oil. When I converted from r12 to 132 the retrofit came with ehster oil already in the can of 134. Fixed a leak now need to recharge. All I can find in cans is pag oil.
Old Aug 18, 2003 | 03:33 PM
scorp508's Avatar
scorp508
Default Re: a/c oil (jtfrog)
When we did mine the other day we had to put 3 oz of ehster into the compressor and I think 6 oz into the lines.
Old Aug 19, 2003 | 12:15 AM
vetteseniorcit's Avatar
vetteseniorcit
DO NOT MIX OILS!!! :nonod:
Old Aug 19, 2003 | 04:52 PM
SunCr's Avatar
SunCr
Stick with ester - it's compatible with whatever trace amounts of mineral oil are still in there from the R12 - Pag isn't, but it is compatible with ester. Try an a/c shop but I'm pretty sure Poop Boys and/or NAPA have ester - just ask for it. Unfortunately, you'll probably have to buy a quart - capacity is 8 ozs.
Old Aug 20, 2003 | 07:34 AM
Stingray1970's Avatar
Stingray1970
Default Re: a/c oil (SunCr)
:iagree: Use ester
To a/c oil
