AKM Molded cable with EASE, will it work???
Old Aug 20, 2003 | 04:43 PM
vvv90's Avatar
vvv90
Default AKM Molded cable with EASE, will it work???
I'm thinking of buying the AKM $95 molded ALDL to serial cable, but it's only verified to work with Datamaster. I'm hoping I can use both.
http://www.akmcables.com/ic.htm
Does anyone know if this will work or not with EASE?
Thanks.
Old Aug 22, 2003 | 02:33 AM
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
Default Re: AKM Molded cable with EASE, will it work??? (vvv90)
I doubt seriously that it will work with Ease as you would like. The Ease interface is specially configured to convert the serial data stream from the cable for the scan tool use. The cable itself will work like an Ease OBD1 cable would, but you still need the Ease interface box.
If you already have the Ease scan tool software and the interface then it might work. If you want to replace an Ease cable that has been damaged, the Ease OBD1 cable is $30 and the OBD2 cable is $60. Either one costs less new than the AKM cable.
Mike
Old Aug 25, 2003 | 11:46 AM
vvv90's Avatar
vvv90
Default Re: AKM Molded cable with EASE, will it work??? (Mike_88Z51)
$30 Really??? Where can I buy it. That's a $65 savings over the AKM cable, and I'd rather use EASE than Datamaster
:cheers: :seeya:
Old Aug 25, 2003 | 01:20 PM
Mike_88Z51's Avatar
Mike_88Z51
Note: Ease does not sell the cables by themselves to non-owners of their products.
If you already have the Ease softwae and interface then I'm assuming you bought an Ease scan tool new from Ease or used from someone else. Ease keeps all owner names on record so you can call their 888-366-3273 number and order a replacement cable under your name or that of the original owner.
You want either an OBD1 or OBD2 cable:
$30.00 CABLE-GM1 ......... GM OBD1 cable
$65.00 CABLE-OBD2-15 .. OBD2 to DB15 Cable for PDA and Personal scan tools.
$65.00 CABLE-OBD2-BLACK .. OBD2 to DB25 Cable for OBD2 vehicles.
If you bought a used scan tool from someone you should be able to get registration changed to show you as the current owner. This helps when ordering software upgrades and cable replacements in the future. As a part-time rep. for Ease I'll be glad to help if you have any other questions about Ease scan tools. Feel free to email me directly.
Mike
mike_88z51@yahoo.com
[Modified by Mike_88Z51, 10:34 AM 8/25/2003]
Old Aug 25, 2003 | 01:52 PM
vvv90's Avatar
vvv90
Mike
:seeya :cheers:
If that's the case then I will purchase both at once. I don't have EASE yet, but the person who burns my chips does and I want to use the same scan tool for obvious reasons.
Thanks!
To AKM Molded cable with EASE, will it work???
