afr 195cc heads with stealthram?
Old Aug 20, 2003 | 05:35 PM
85vettelovin's Avatar
85vettelovin
Default afr 195cc heads with stealthram?
I'm getting to the closing stages on my 383. Can anyone tell me what kind of number my stock 85 heads flow? Also would the afr 195cc heads work weell with the stealthram? And where is a good place to buy the heads from? This will be a nitrous motor. :party:
[Modified by 85vettelovin, 3:54 PM 8/20/2003]
Old Aug 20, 2003 | 06:11 PM
vader86's Avatar
vader86
Default Re: afr 195cc heads with stealthram? (85vettelovin)
Any head will be better than the stock set. They max out around 300hp.
The 195s would make a big difference. Get them directly from AFR, airflowresearch.com
Old Aug 20, 2003 | 06:18 PM
pablocruise's Avatar
pablocruise
I'm running AFR 210's under the Stealthram (on a 391 stroker) and there is NO "wall" that you run into at 4800 RPM like the TPI's we had. The RPM's zing up very fast and I can only see valve float(hyd cam) keeping you at 6500 +/- RPM. It breathes like crazy. To me, the torque curve felt flat and keeps going up and up.
If ordering directly from AFR, budget 3 months for them to get you the heads. Try other speed shops to see if they have them laying on a shelf.
[Modified by 89 Paul in Cal, 3:22 PM 8/20/2003]
Old Aug 20, 2003 | 06:23 PM
85vettelovin
Default Re: afr 195cc heads with stealthram? (89 Paul in Cal)
what kind of compression would I be looking at with these heads?
Old Aug 20, 2003 | 06:36 PM
pablocruise
Your choice.
My main considerationis the octane I have avalaible around here(only 91 :cry ) as it is my daily driver. Were it a drag only car, I would've milled the heads and cut my pistons to bring about 12:1 using race gas.
I have 10:1.
Just be sure to specify corvette L98 plug angle
Old Aug 20, 2003 | 06:40 PM
85vettelovin
Are you using domed pistons?
Old Aug 20, 2003 | 06:43 PM
pablocruise
No, but they do have the reliefs for the valves.
To afr 195cc heads with stealthram?
