Verts and body flex!!
Old Aug 21, 2003 | 03:04 AM
RichAshley-Black99's Avatar
RichAshley-Black99
Default Verts and body flex!!
What can be done to stiffin it up also the dash makes noises with the flexing of the car is there something that can be put between the dash pieces to queit them?Ive tightened all the parts but with the body flexing they still make noise. Im really thinking of moving to a coupe. :nonod:
Old Aug 21, 2003 | 03:41 AM
dgoodhue's Avatar
dgoodhue
Default Re: Verts and body flex!! (AshleyRL-87Conv)
C4 Coupe aren't that much stiffer (with the targa out coupe are even more flexible than conv.)
Old Aug 21, 2003 | 04:19 AM
RichAshley-Black99
Default Re: Verts and body flex!! (dgoodhue)
I guess Ill see what I can do this weekend I might tear all the dash interior pieces out and see if I can find some sort of foam type stuff or something.
Old Aug 21, 2003 | 07:17 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers: Gently re torque all the screws you can find
My 88 remains squeak and rattle free, but I do retighten...gently...all the screws, etc. every 6 months
:seeya :steering:
Old Aug 21, 2003 | 07:52 PM
Caboboy's Avatar
Caboboy
Rich, long time Bud :seeya
It's not the tightness so much as it's the bezel(s) where the openings lay against the various displays. They rub against each other and make the squeaks. Some very very thin insulation (or black electrical tape) should fix most of it. Just take the bezels off and use the tape sparingly as kind of an insulator wherever you think you might need it! Be careful running the screws back in, cause the holes crack out easily (ask me how I know) :lol:
Old Aug 21, 2003 | 10:43 PM
chaos on wheels's Avatar
chaos on wheels
Also check the X-brace bolts. Some of mine had loosened up once. One had backed over half way out!!
After tightening up all the bolts, car is as tight as ever! :steering:
Old Aug 21, 2003 | 10:59 PM
RichAshley-Black99
Default Re: Verts and body flex!! (Caboboy)
Tim how you doing? yeah its been awile I just got back from the gulf about a month ago and its just been so busy with work and family I havnt had much time for the forum or the car. Ill look over it this weekend and give the tape a try. Thanks all :cheers: :seeya
To Verts and body flex!!
