Whats wrong??-SES light and no blink!!89vert
Re: Whats wrong??-SES light and no blink!!89vert (Wheelman)
Wheelman: Please tell me how to post pictures. I do not have a location on the web for pictures??? :withstupid:
Re: Whats wrong??-SES light and no blink!!89vert (Sam Lam)
if your pictures are on another site all you have to do is copy the url of the picture between image tags like this:
(img)http://www.sitehere.com/pic1.jpg(/img) except replace the ( and ) with [ and ].
If you want to post pictures that you have saved on your computer, the process to post them is the same except you need to upload them to some webspace first. You can sign up for some free photohosting space here.... www.photohost.org
hope this helps
:cheers:
hope this helps
:cheers:
- 1986 Original Owner -
Maybe this is a dumb suggestion but are you sure you are grounding the right pins?? I have accidently tried grounding the top left two before and got no light and didnt realize til weeks later that its actually the top right two pins that are labeled a&b.
[Modified by Ray Quayle, 5:38 AM 8/26/2003]
Cruise-In II Veteran
Re: Whats wrong??-SES light and no blink!!89vert (Ray Quayle)
Yes,i have been jumping the upper right pins and fans come on. I used the fax sheet that was sent by SAM LAM(thanks again!!). I did what it said.Pins jumped,ign. on---SES on-no flash. Turn off car,disconnect ecm,turn on car(still have pins jumped) no light. Turn off car,reconnect ecm,test light at terminal B, no SES light. My final analysis is BAD ECM. Hopefully that is right i might have the order messed up bbut that is what i remember doing.
The paper is out in the garage,right now.
I was going to buy from AUTOZONE tomorrow for $82 exchange,I have the PROM already removed. GET THIS-------the case of the computer says it is ALREADY remanufactured by DELCO!!!!!
Matt :( :(
Matt :( :(
Re: Whats wrong??-SES light and no blink!!89vert (6spd89)
Here is the service number of the case---01227165.
Here is the number off the ecm connection---975061204295336
I don't know if you can do anything w/ those but i thought i would share anyway!!
Matt :cheers:
Matt :cheers:
Matt: glad I was able to help you on the ECM problem. I highly recommend you get a Helms manual as you will have other problems in the future. My Helms has paid for itself many times over! I often see them on Ebay at a reasonable price. Mine was $90 when new and it is now well worn. Regards, Sam
Thanks again Sam!!! I just need to decide where to buy it now. It IS already a remanufactured unit from Delco. Sticker says so,but according to Superior Chevy ,my ECM has had 4 revisions to it!!! Nice boards GM!!!!!! JEEZ!!
I might go aftermarket,still deciding........
matt :crazy: :crazy:
