91 vette going slower
Old Aug 22, 2003 | 06:01 PM
6spd's Avatar
6spd
Default 91 vette going slower
i just installed 24# injectors ford and had a custom chip burned for the injectors and other stuff now it feels like the car is falling on it's face when i nail it the fuel pressure is set to 45psi with the vaccum line off. please help
Old Aug 22, 2003 | 06:25 PM
vetracer's Avatar
vetracer
Default Re: 91 vette going slower (6spd)
I think I had the same problem when I changed to 24# injectors. Mine would hesitate badly from low RPM. Lowering the fuel pressure and having the chip reprogrammed didn't help. Eventually I had the original GM injectors cleaned at Cruzin Performance and put them back in. Hesitation disappeared and the car just seemed to run stronger IMO. Probably not what you want to hear - just my 2 cents, when I posted this problem 6 months ago a lot of guys using them said they had no problems.
45 PSI sounds like too much FP for the 24# injectors, you might be too rich as well.
[Modified by vetracer, 4:27 PM 8/22/2003]
Old Aug 22, 2003 | 06:31 PM
6spd's Avatar
6spd
Default Re: 91 vette going slower (vetracer)
yes your right that's not what i wanted to hear but i was told if you put 24#''s in and have the chip programmed for it would be fine???????
Old Aug 22, 2003 | 09:05 PM
6spd's Avatar
6spd
did anyone else have this problem????????
To 91 vette going slower
