.5 volt drop when in reverse - why and anyone else ?
Old Aug 22, 2003 | 10:35 PM
Stingraynut's Avatar
Stingraynut
Default .5 volt drop when in reverse - why and anyone else ?
Another forum member told me his car loses 1/2 a volt when in reverse. I jokingly said I'd check mine to see if it was 'normal' -
I just checked and mine loses .5 volt too !!!!
Anyone else have this happen and does anyone know why ?
Here's my test procedure -
Cold start -RPM 1100- volts 13.8/13.9
Shift into reverse. Raise RPM back to 11000 – Volts 13.3/13.4
S'nut
Old Aug 22, 2003 | 10:38 PM
scorp508's Avatar
scorp508
HID reverse lights? :D
Old Aug 22, 2003 | 10:50 PM
jfb's Avatar
jfb
Default Re: .5 volt drop when in reverse - why and anyone else ? (Stingraynut)
Pull the stop/haz fuse and try it again. If you don't see 0.5 volt drop, the cause is due to voltage drop from the stoplight current through the ign sw. The dash voltmeter measures the voltage after the ign sw and thus includes any voltage drop from current through the ign sw.
Old Aug 23, 2003 | 09:18 AM
Stingraynut
Default Re: .5 volt drop when in reverse - why and anyone else ? (jfb)
Thanks jfb,
it seems a really strange thing. I'll do the fuse check tomorrow.
Judging from your reply, I suppose it's normal, but I wonder if our vette's did it from new or is there now more resistanec in the complex circuitry caused by having a f'glass body.
Anyone else have some theories etc ?
S'nut
Old Aug 23, 2003 | 02:23 PM
mitchcole's Avatar
mitchcole
my voltage goes up and down at idle with the blinkers on... It just seems slow to react to load changes...
Other than that - I dunno!
To .5 volt drop when in reverse - why and anyone else ?
