Started my 383 buildup!!! Pics within>>>>>>
Old Aug 22, 2003 | 10:55 PM
NUckINg FuTS's Avatar
NUckINg FuTS
Default Started my 383 buildup!!! Pics within>>>>>>
Finally I got a chance to get my hands dirty after having my 383 shortblock sitting in the garage for quite some time collecting dust!
Here's the 383 shortblock in all its glory:
A couple facts and about the block. I bought this shortblock used but it only has a couple thousand miles of use. Looks brand new! It was assembled by Scott's performance shop in Aurora, IL. Internally included is a stroker crankshaft, ofcourse. Don't know what make it is though. GM Pink rods, and SRP forged flat top pistons. Oh yeah and 4 bolt mains. One good thing about the block being slightly used is there is no break in period! LOL
Todays project included installing the camshaft:
Specs on this cam are as follows:
Hydraulic flat tappet
.496/.520 lift with 1.6 rockers
224/234 duration
112 CL
Cam all greased up ready to install:
And finally, cam installed with Pete Jackson "Quieter" gear drive:
Stay tuned tomorrow as I continue assembley on the 383..........
[Modified by NUckINg FuTS, 10:10 PM 8/22/2003]
Old Aug 22, 2003 | 10:58 PM
VetteNoob's Avatar
VetteNoob
Default Re: Started my 383 buildup!!! Pics within>>>>>> (NUckINg FuTS)
:cool: how long did you leave the short block sitting around? did you do anything to prevent surface rust?
Old Aug 22, 2003 | 11:02 PM
NUckINg FuTS
Default Re: Started my 383 buildup!!! Pics within>>>>>> (VetteNoob)
Wow I has just finished reviewing my post and already got a reply.
It's been sitting around a month or so. But it felt like eternity! Anyway. I lubed it up really well when I first got it so there is absolutely no rust anywhere.
Old Aug 22, 2003 | 11:05 PM
scorp508's Avatar
scorp508
Looks like fun! Eeek gear drive.....
Old Aug 22, 2003 | 11:06 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
What heads and cam are you going to use? 4 Bolt I assume. Looks pretty good.
Good Luck in the build. Oops the cam sounds great. should be fine.
Good foundation.
tony
[Modified by oldace84, 8:08 PM 8/22/2003]
Old Aug 22, 2003 | 11:13 PM
NicBig's Avatar
NicBig
Tomorrow I start tearing down my 79 for a 383 rebuild. What h.p. do you think you'll have and is your Vette a daily driver or racer?
Old Aug 22, 2003 | 11:22 PM
ZAD54's Avatar
ZAD54
Default Re: Started my 383 buildup!!! Pics within>>>>>> (NicBig)
Keep up the great pics, I'm going to follow this one to the end. :thumbs:
Old Aug 22, 2003 | 11:24 PM
scorp508's Avatar
scorp508
Anything I should know about the gear drive other than they're loud and possibley obnoxious??
Well, better throttle response. :)
Old Aug 22, 2003 | 11:33 PM
JADVette94's Avatar
JADVette94
Default Re: (scorp508)
:cool:
Dumb question: To build a 383, do you bore out your 350 or stroke it or both? Why not a 396?
[Modified by JADVette94, 4:34 AM 8/23/2003]
Old Aug 22, 2003 | 11:41 PM
scorp508's Avatar
scorp508
Default Re: (JADVette94)
:cool:
Bore: 4.030"
Stroke: 3.75"
A 396 requires a 3.875" stroke and there are only forged cranks for that which get mighty expensive compared to a nice Scat 9000 cast 3.75" crank that goes for $249 and can handle 600hp. :cool:
Old Aug 22, 2003 | 11:42 PM
NUckINg FuTS
:cool:
A 383 is a 350 bored .30 over and using a 400ci crankshaft. Don't know about a 396 though.
Old Aug 22, 2003 | 11:43 PM
NUckINg FuTS
I'm hoping for 400-450HP. It's a daily driver.
Old Aug 23, 2003 | 01:14 PM
offershore's Avatar
offershore
2327=876=385=xroqdf>2323435;6879;ot1lsi" border=0> That look's like a dished piston to me. :crazy:
Old Aug 23, 2003 | 01:55 PM
mitchcole's Avatar
mitchcole
Default Re: Started my 383 buildup!!! Pics within>>>>>> (offershore)
Aren't the 383s supposed to have dished pistons? I thought there was more compression due to the longer stroke. That looks like 10cc with the releifs?
Old Aug 23, 2003 | 02:25 PM
Goody's Avatar
Goody
Default Re: Started my 383 buildup!!! Pics within>>>>>> (mitchcole)
Use can use 1 pt higher compression if using aluminum heads. I'm debating the 383/396 issue for a daily driver.
Old Aug 24, 2003 | 06:02 PM
offershore's Avatar
offershore
C/R is determined by many things, he said he had flat top pistons,those are not flat top.
Old Aug 24, 2003 | 06:39 PM
NUckINg FuTS
Yes your right they're not flat top they're dished.
To Started my 383 buildup!!! Pics within>>>>>>
Old Aug 25, 2003 | 10:15 AM
grumpyvette's Avatar
grumpyvette
http://www.newcovenant.com/speedcraf...ssionratio.htm
with 67 cc heads and a .021 head gasket to keep your QUENCH distance close to correct youll have about STATIC 10.2 cpr (if you use those felpro #1003 head gaskets that are only designed for cast iron heads and that are .041 thick and have a 4.166 bore)(youll be at about 9.76 cpr)your DYNAMIC COMPRESSION WILL VARY WITH THE CAM YOU PICK,
BTW that calc site has one bad instruction, the piston should have a NEG.# for valve notchs and a POSSITIVE number for a piston dome, the pistons in that short block have about a neg. 8-9 cc fo entering into the compression calc.
[Modified by grumpyvette, 3:39 PM 8/25/2003]
Old Aug 25, 2003 | 10:22 AM
cyclerage23's Avatar
cyclerage23
Good luck!
I will be in your shoes soon.
Old Aug 25, 2003 | 03:21 PM
Togo's Avatar
Togo
Default Re: Started my 383 buildup!!! Pics within>>>>>> (cyclerage23)
Good luck!
at least there will be NO break in period! :jester
my shortblock is just sitting in the garage :sad: (how sad for me) i am trying to concentrate on my other vette and plan on buying Bill Reids 355 as soon as he pulls it out -- then i pull my old worn 180K 350 out and replace!
man i can't wait to drive a vette again!!!
