5th tail light... dumb question
Old Aug 22, 2003 | 11:58 PM
Dark-Knight's Avatar
Dark-Knight
Default 5th tail light... dumb question
Should the 5th (center) light on my '95 act as a brake light like the other four?
Thanks! :seeya
Old Aug 23, 2003 | 12:48 PM
blk90rdstr's Avatar
blk90rdstr
Default Re: 5th tail light... dumb question (Beautiful Beast)
yes its a center mounted stop light.
Old Aug 23, 2003 | 01:08 PM
bstirn's Avatar
bstirn
Yep :yesnod:
Old Aug 23, 2003 | 07:05 PM
Dark-Knight
Default Re: 5th tail light... dumb question (blk90rdstr)
Yiipes! Mine's not working at all, how can I get to the bulb?
Old Aug 23, 2003 | 08:10 PM
c4cruiser's Avatar
c4cruiser
Should be able to remove the rear license plate and reach up thru the space.
Old Aug 23, 2003 | 09:59 PM
ittlfly's Avatar
ittlfly
Default Re: 5th tail light... dumb question (c4cruiser)
You can also drop the spare and go at from the bottom. It's a little tight but doable.
Old Aug 23, 2003 | 10:19 PM
Dark-Knight
Thanks guys, sounds better than tearing through the interior! :seeya
Old Aug 24, 2003 | 08:17 AM
vetteseniorcit's Avatar
vetteseniorcit
Ain't no such thing as a dumb question. As my flight instructor once told me, "we all start with the same number of hours: Zero!" The owners manual says to remove the license plate, rotate the bulb socket 1/4 turn counterclockwise and pull out. It also reminds you to replace your license plate! I love the guys who write these things! :D
Old Aug 24, 2003 | 10:07 AM
c4cruiser's Avatar
c4cruiser
BTW, if you replace the bulb and the light still does not come on, check the brake light switch at the base of the steering column. The wire for the CMHSL runs from the switch to the bulb as a separate lead and I think it's light blue in color. The switch has a separate contact inside for the CMHSL and if that fails, your service brake lights will still work. The fix is to replace the switch assembly.
Old Aug 24, 2003 | 04:02 PM
Dark-Knight
Default Re: 5th tail light... dumb question (vetteseniorcit)
Vettesr..
Thanks my manual says to go thru the gas cap area, thanks I'll try your way first!
Cya! :seeya
Old Aug 24, 2003 | 04:05 PM
Dark-Knight
c4cruiser, thanks! Center light will not work as brake light or when I turn the lights on. I'm guessin' it's the bulb but thanks for the tip in the switch!
Cya! :seeya
Old Aug 25, 2003 | 09:11 AM
Dark-Knight
Well, changed the bulb, still not working, :skep: . Gues next thing to check are fuses then the switch at the base of the steering column.
More tips are apprecaited, thanks guys! :seeya
Old Sep 4, 2003 | 06:56 AM
Dark-Knight
Got it to work! Thanks all! Your tips did it! :hurray:
To 5th tail light... dumb question
