In my efforts to cool down my 89 engine temp. i have a question? Hypertech claims to more aggressive timing and fuel curves for more power. What about engine temp. when fan kicks on? DOES HYPERTECH TURN ON FAN (ONLY 1 FAN) SOONER- LOWER ENGINE TEMP.
Dont bother with a hypertech chip...you can have the fan come on sooner by changing the fan switch to one that kicks them on at a lower temp.The switches are usually less than 20 bucks.I used this on my 86 to turn the fan on at 200 and off at 190 degrees.It works great.Dont need a 100+ dollar chip to do that.
Also,be sure the area between the radiator and a/c condensor is clear of debris.This is a common problem with C4's.This area fills up with leaves and junk that it blocks airflow.I usually clean this area out once a year.
As far as power goes,your best bet is to have a custom prom made instead.
Ive tried hypertech and ads chips before and was not impressed.
