Power Antenna Relay
Old Aug 24, 2003 | 11:16 AM
polishdevil
Default Power Antenna Relay
I wasn't able to get the power antenna to work after getting rid of the bose and putting in a kenwood, so now i plan on going straight for the relay and running a cable from there. I searched the forum and found three posts about this all saying that the relay should be under the rear trim, all i found was the hatch poper relay.
I have the GM service manual and it has a picture of the relay but i can't figure out where it is?
Any help would be greatly appreciated,
Dave :confused:
Old Aug 24, 2003 | 11:37 AM
IBEAM700's Avatar
IBEAM700
From: Looks like I picked the wrong week to stop sniffin glue Orlando
Default Re: Power Antenna Relay (polishdevil)
It’s usually within 2 feet of the antenna. I have a convertible, and it’s in the rear corner of the convertible top compartment on the driver’s side. I would guess the coupe relay would be in the same general area. I’m going to take a wild guess and say it’s behind the rear speaker on the driver’s side.
The factory service manual should tell you where all the components are located on or in the chassis.
:chevy :cheers:
Old Aug 24, 2003 | 12:07 PM
polishdevil
Default Re: Power Antenna Relay (IBEAM700)
Here's what's under the black trim panel, relay should be on the left side?
Thanks,
Dave
Ezcuse the filthy car and poopiety pic
Old Aug 24, 2003 | 01:55 PM
okinawa86vette's Avatar
okinawa86vette
On my '88 and '86, the antenna relay was underneath the rear deck trim (center piece) on the driver side, about half way between the hatch solenoid and the outside edge of the car. It was mounted to the back of the inside of the body, of I remember. If you follow the power wires from your antenna from where it enters the interior in the back corner of the interior, underneath the trim pieces, it will lead to the relay.
I hope this helps.
Chris
Old Aug 24, 2003 | 02:27 PM
polishdevil
Default Re: Power Antenna Relay (okinawa86vette)
Well the 3 wires come into the car, and plug into a harness, no relay anywhere???
any ideas where else it might be???
Dave :confused:
Old Aug 24, 2003 | 02:51 PM
IBEAM700's Avatar
IBEAM700
#2 of your diagram indicates storage bracket. Check down in the bottom of your storage compartment behind the driver’s seat. The connection in the picture may just be a junction point with the body harness that will meet up with the relay further downstream. :cheers:
Old Aug 24, 2003 | 03:08 PM
polishdevil
good idea, will do :cheers:
Old Aug 24, 2003 | 10:14 PM
okinawa86vette
Guess somewhere between 88 and 93, they changed it. Sorry I wasn't much help.
Good luck
Chris
Old Aug 26, 2003 | 01:25 PM
polishdevil
Well i just cut the pink wire on this plug, ran new wire to the radio and it works, no idea where the relay is.
Thanks for all the help,
Dave
To Power Antenna Relay
