Low Oil Pressure
Old Aug 24, 2003 | 01:13 PM
94AdmiralCoupe's Avatar
94AdmiralCoupe
Default Low Oil Pressure
The check gauges light is coming on when I take my foot off the accelerator and the oil pressure gauge drops to almost zero. I checked the oil level and it is normal. Can anyone provide any insight before I head to the shop?
Old Aug 24, 2003 | 01:34 PM
J Z06's Avatar
J Z06
Sounds like the oil pump could be on it's last legs. :(
Old Aug 24, 2003 | 01:42 PM
scorp508's Avatar
scorp508
Default Re: Low Oil Pressure (Jay 383)
Could be an oil pressure sending unit with a bad connection.
Old Aug 24, 2003 | 04:43 PM
94AdmiralCoupe
Default Re: Low Oil Pressure (94AdmiralCoupe)
Thanks for your help, guys.
Old Aug 24, 2003 | 06:10 PM
vader86's Avatar
vader86
Replace the sender first, then the oil pump if the problem returns. The sending unit is fairly cheap.
Old Aug 24, 2003 | 06:43 PM
Bear86's Avatar
Bear86
Replaced the Sending unit, not it. Replaced oil pump with a Moroso high volume. Oil pressure OK now.
Good Luck
Larry :seeya :seeya :seeya
Life is not measured in the breaths you take, but
in what takes your breath away.
To Low Oil Pressure
