Quad driver question
Old Aug 25, 2003 | 12:14 AM
loflyin's Avatar
loflyin
Default Quad driver question
On 86, can anyone tell me what functions are grouped into each quad module - trying to figure out if one had gone bad. Continue having problem with EGR, CTS, Code 42. EGR is new, vacuum lines replaced and voltage at solenoid is correct. Diagnostic switch at 12 volts. CTS replaced along with pigtail. 5 volts on feed, 2 volts on return - throws Code 14 (not all the time). Cooling fan comes on with ignition on, no matter how cold. Fan relay new and checks out good. Distributor has new cap, rotor, ign coil, module has checked good 5 times and pick up coil readings are correct. Tan bypass wire was butchered by previous owner, so this was fixed and now have continuity on this circuit. Ready to replace ECM, but want to feel sure that is the problem. Beginning to become very tired of this project and need some help. Thank you if you have a clue and can share it with me.
