LTPWS sensor replacement questions...........
Old Aug 25, 2003 | 02:08 PM
bgrant_12002's Avatar
bgrant_12002
Default LTPWS sensor replacement questions...........
I'm getting ready to replace the orig tires on a 96. I have one sensor that is bad. I'm thinking about just bagging them all.........since I've already pulled the LTPSW light out of the dash.
I dont know what they look like, but I have heard that they are connected to the valve stem............If I take them out completely, can I just replace them with regular valve stems?
:smash:
Old Aug 25, 2003 | 04:17 PM
FX GS's Avatar
FX GS
Default Re: LTPWS sensor replacement questions........... (bgrant_12002)
They are attached to a strap around the circumfrence of your wheel. When you have the shop demount the old tires to put the new ones on, just have them remove the strap with the sensor.
Old Aug 25, 2003 | 06:27 PM
tkrussell's Avatar
tkrussell
Default Re: LTPWS sensor replacement questions........... (FX GS)
If you are careful in removing them, they are valuable. New ones are expensive. Put them up for sale in the forum.
Old Aug 25, 2003 | 10:24 PM
bgrant_12002
Default Re: LTPWS sensor replacement questions........... (tkrussell)
So, there's no valve stem issue?
Old Aug 25, 2003 | 10:27 PM
FX GS's Avatar
FX GS
Thats correct. The sensored valve stems started with..........well you guessed it, the C5's
To LTPWS sensor replacement questions...........
