is this causing the abs sensor to go off?
Old Aug 26, 2003 | 04:43 PM
mistaben's Avatar
mistaben
Default is this causing the abs sensor to go off?
following the two steel brake lines up to the brake cylinder - right in between the front brake line and rear brake line is a broken plug that connects to a wire of some type. would this broken plug cause the abs sensor to go off? autozone doesn't even know what the part is, and my ALDL port (is that what it is called) shows only code 12.
sorry if description is bad i just bought the car and am learning lots of things on it fast. btw. it is a 91 conv.
Old Aug 27, 2003 | 03:59 AM
Q1KSLVR's Avatar
Q1KSLVR
Default Re: is this causing the abs sensor to go off? (mistaben)
Sounds to me like the proportioning valve switch wire. It isn't an ABS problem and with it disconnected the "brake" light will not come on if there is a failure in the hydraulic brake system.
I would get it fixed ASAP.
PS, stay away from "Autozone", and go to a good shop or GM dealership!
Old Aug 28, 2003 | 02:16 AM
mistaben's Avatar
mistaben
Default Re: is this causing the abs sensor to go off? (Q1KSLVR)
do you know what costs off the top of your head?
Old Aug 29, 2003 | 11:09 PM
gybonz's Avatar
gybonz
Cruising
Bring it in and have it fixed- don't mess w/ brakes! My daily driver (94 G Am) had a broken sensor wire which was a fairly cheap fix ( $40 aside from the $90 dignostic). Do you have the BRAKE warning vs. the ABS warning?
Old Sep 1, 2003 | 02:38 AM
mistaben's Avatar
mistaben
Default Re: is this causing the abs sensor to go off? (gybonz)
brake light on top of the tach parts comes on at start up. ABS on the right dash part just comes on stays on. so does the low oil light, but the sensor has been removed.
Old Sep 1, 2003 | 10:55 PM
dizwiz24's Avatar
dizwiz24
On my 93 car, I found the inductive sensor on the rear hubs to have all kinds of gunk/metal filings sticking to it (must be a magnet).
With a rear wheel removed, it was easy to remove the sensor (one screw) pull it out and clean it off.
Cleaning off both rear wheel lock-up sensors seemed to prevent the cars ABS light from going off as much during normal driving.
THe front ABS sensors are unaccessible, as they are integral with the hub/bearing assembly.
Old Sep 2, 2003 | 12:57 AM
mistaben's Avatar
mistaben
Default Re: is this causing the abs sensor to go off? (dizwiz24)
so it is a WD-40 job on the rear?
anyone have any experience with the front ones?
Old Sep 2, 2003 | 02:15 PM
Steel Blue 91's Avatar
Steel Blue 91
Sounds to me like the proportioning valve switch wire. It isn't an ABS problem and with it disconnected the "brake" light will not come on if there is a failure in the hydraulic brake system. I would get it fixed ASAP.
I agree. Get that part fixed.
Is your ABS light on constantly? The unit will self test at around 3 MPH. The light will come on briefly and the ABS unit will "moan".
Old Sep 4, 2003 | 02:35 AM
mistaben's Avatar
mistaben
Default Re: is this causing the abs sensor to go off? (Steel Blue 91)
ABS light on constantly... dont know about the moaning sound at 3mph. were can i get this part anyone know?
Old Sep 4, 2003 | 01:27 PM
Tourney3p0's Avatar
Tourney3p0
I'd be willing to bet that you have a bad sensor.
When I first bought my 88, my ABS light would come on as soon as I started moving. Since the ABS module is pretty much non servicable (to people like me), I started with the wheel sensors.
You'll need to take the rear wheels off to get to the rear sensors, but only one bolt holds it in. Pull it out and clean it. On mine, one of my rear sensors visibly had the notch on the end broken off somehow. I was able to access and remove my front sensors by just turning the wheels and removing the bolt. All four of them were covered with dirt and stuff, which I cleaned, but replacing the one that was broken fixed my problem.
Old Sep 4, 2003 | 09:08 PM
dizwiz24's Avatar
dizwiz24
the moaning noise at about 4 mph is a normally self-check of the ABS.
When I first heard it, i thought it was a bad wheel bearing, ujoint or something.
To is this causing the abs sensor to go off?
