Good throttle body/Intake cleaner??
Old Aug 26, 2003 | 09:07 PM
JB666's Avatar
JB666
Default Good throttle body/Intake cleaner??
What's a good cleaner for the TB/Intake? I just ran a bottle of Chevron Injector cleaner, and want to finish the job.. Any recommendations?? I know you can't do a 100% thorough job by cleaning the TB with it mounted, but I still want to give it a shot......
Thanks!
Old Aug 27, 2003 | 02:48 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Good throttle body/Intake cleaner?? (Jbaker)
I think Gumout makes a cleaner; be sure it says for TBs, not just carbs.
Old Aug 27, 2003 | 10:11 AM
MagikDraggin's Avatar
MagikDraggin
Cruise-In IV Veteran
Cruise-In V Veteran
I'm going to have to show my ignorance and ask what I hope is not too silly of a question, but why would anyone need to "clean" the throttle body anyway? Only air goes through it, and not any fuel, right?
What am I missing here?
Old Aug 27, 2003 | 10:15 AM
JB666's Avatar
JB666
Default Re: Good throttle body/Intake cleaner?? (MagikDraggin)
Not a stupid question at all... Take off your intake closest to your TB and run your fingers along the butterfly, and I'll bet you come out with a couple of black fingers... If not black, at least dirty... Crap builds up in there.
Old Aug 27, 2003 | 10:19 AM
JCascia's Avatar
JCascia
CRC cleaners are some of the best out there. Use throttle body cleaner and
an old tooth brush, get 2 cans if its really bad. Heavy duty rubber gloves are good to have for this task also. Oh yea, dont forget saftey glasses! :D
Old Aug 27, 2003 | 10:22 AM
JB666's Avatar
JB666
Default Re: Good throttle body/Intake cleaner?? (JCascia)
Ok, I have a stupid question now... Do you leave the car running, or does it have to be off? Like the old carb cleaner, you leave it running, while feathering the throttle, and it smokes like a burning building!!
Old Aug 27, 2003 | 01:58 PM
Chefskeez6's Avatar
Chefskeez6
I have gumout and i think it says to spray it while its running, either way it should say on the cleaner.
Old Aug 27, 2003 | 05:53 PM
JB666's Avatar
JB666
Default Re: Good throttle body/Intake cleaner?? (Chefskeez6)
Ok, well I got a can of STP, and it says spray with engine off. I also got a can of gumout, and it says you can do it either way.. So, I'm assuming it won't hurt anything to run the cleaner through your tb?!?
Old Aug 27, 2003 | 07:19 PM
ittlfly's Avatar
ittlfly
What ever you decided to use, be sure it is sensor friendly. If not you'll be in for a nasty surprise. :D
To Good throttle body/Intake cleaner??
