I finally got my cheep ebay IBM ThinkPad working with WinALDL. :hurray: Who knew that you needed a special ThinkPad Configuration tool to turn on the serial port. :confused: Any way at idle my BLM is 116. It’s an 85 so only one O2 sensor. Looks like I am a little rich. I have Ford 21 lb. injectors and 40psi fuel pressure. Is this anything to worry about. How low can I go with the fuel pressure.
The combination of higher pressure and injectors would likely make the computor sense a rich condition. I would look at how many changes (counts) that the OX sensor goes from rich to lean. If it is changing back and fourth, it will probably be OK.
I drove it around with the BLM chart turned on. I saw lots of points where BLM is between 124 - 128'. The rich/lean counter changes often to. I think I am OK with the fuel pressure.
One thing I saw in the flag data was ".DRP occured". What is a DRP?
This WinALDL scanner is very cool. Thank You Jonas. :cheers:
