Standard O2 sensors...
Old Aug 28, 2003 | 09:10 AM
Daniel DK's Avatar
Daniel DK
Default Standard O2 sensors...
Wich brand/type was standard on the 92? also how far down the pipe can you safely mount them?
Thanks in adv.
:cheers:
Daniel
Old Aug 28, 2003 | 09:15 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: Standard O2 sensors... (Daniel DK)
Stock was probably AC Delco, 1 wire. If you want to move them further down the pipe you might need to convert to heated ones.
If you don't mind me asking why? Doing headers or something?
Old Aug 28, 2003 | 09:27 AM
Daniel DK's Avatar
Daniel DK
Default Re: Standard O2 sensors... (Nathan Plemons)
i've never seen the stock setup - there isn't excatly a lot of vettes around where i live.. :sad: Mine has an aftermarket borla catback system and some custom fabricated stainless 3" pipe. The two cats have been replaced by a single cat after the Y pipe. I'm having some problems with it running way rich (datamaster displays around 64 blm!!!) and i'm suspecting the o2s aren't working like they should. i'm a TOTAL newbie to datamaster and scanning software in general... so i really don't know what an healty o2 censor should look like..
Old Aug 28, 2003 | 09:38 AM
ittlfly's Avatar
ittlfly
When I replaced mine, I ordered new OEM through Jeff @ Superior Chev. He sent me 2 Bosh. I'm guessing there're OEM.
Old Aug 28, 2003 | 09:51 AM
Nathan Plemons
Who the hell would replace a dual cat setup with a single cat?
The way it is supposed to work is simple, it should have one O2 sensor on either manifold before the stock cats. This puts them pretty far forward which they need to be since they are unheated sensors. If they are further down the pipes they may not be getting hot enough to work properly.
You're right the BLM's are way out of wack. The O2 sensors have to be giving it some data otherwise it wouldn't be creating those strange BLM's. Basically it's creating that strange BLM based on the readings it is getting from the O2 sensors. What you'll want to look at is the O2 sensor voltages. It should bounce back and forth between .100 (lean) and .900 (rich). .500 should be stoich
Old Aug 28, 2003 | 10:32 AM
Daniel DK's Avatar
Daniel DK
The stupid **** who had the car before me! I dunno what he was thinking! :cuss
i was suspecting this... they are placed some 15" down pipe... i'm gonna move em up to some 2" after the flaring... also i've cut out the cat and i'm going to put some flanges on it so that i may replace it with a "test pipe" when the smog-***** aren't looking :-)
I am getting a mv reading from them but they aren't excately bouncing back and forth, they are more like slowly moving from 400 mv to 600 some mv...
I think ill be lurking some more in the scan/tune section :)
:cheers:
Daniel
Old Aug 28, 2003 | 10:34 AM
Daniel DK's Avatar
Daniel DK
Default Re: Standard O2 sensors... (ittlfly)
ok cool - i can buy engros at bosh electronics yay :party:
now all i need is a part# from bosh
:cheers:
Daniel
To Standard O2 sensors...
