89 TPI idle problems, please help
Old Aug 28, 2003 | 08:07 PM
scarabexc's Avatar
scarabexc
Default 89 TPI idle problems, please help
I just bought this 89 and it seemed to idle ok, just a little low. Then it got to where it wouldn't even stay running. So I turned the idle up and got it idling fine. The next day I started it and it was way too high. So I backed it off, next day it was way to low!!!!! No service engine codes, please advise, Thanks :banghead:
Old Aug 28, 2003 | 08:13 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Default Re: 89 TPI idle problems, please help (scarabexc)
You cannot adjust the idle on an L-98 with the screw, it is set by the ecm.
Start by reading the tech tips under tools above ^.
I would remove and completely clean the TB, I would replace the IAC while you are there. Use a new gasket and re-torque the TB bolts a couple times after heat cycles.
Read the tech tips!
Pete
Old Aug 28, 2003 | 08:49 PM
CarAteMyMoney's Avatar
CarAteMyMoney
Clean your IAC, then reset the IAC and TPS. Your car will love you for it :cheers:
To 89 TPI idle problems, please help
