Temputre saying LOW?????
Old Aug 29, 2003 | 05:47 PM
bwagner's Avatar
bwagner
Default Temputer saying LOW?????
Driving today my car starting acting like it was going to stall out. I saw that the temputer was showing the word "LOW"...then it would start bouncing around, going from 188 down to 177 back up, back down, so on and so on. Then it would run fine, then back to showing "LOW" etc...... Does anyone know what would be causing this????? HELP.....Oh, I've put in a new radiator about 2-3 months ago. So I don't think it's anything to do with that. Maybe a sencor????
[Modified by bwagner, 5:47 PM 8/29/2003]
Old Aug 29, 2003 | 05:53 PM
Strick's Avatar
Strick
Default Re: Temputer saying LOW????? (bwagner)
You're talking about the digital temp read out? It printed "LOW"? Gee, learn something new every day. I'd look at the connector to the sensors on the water pump and on the side of the engine.
Old Aug 29, 2003 | 06:06 PM
bwagner's Avatar
bwagner
Default Re: Temputer saying LOW????? (Strick)
Yeah, sorry it's a 94 and it has the digital read out. It was the weirdest thing, I've never seen it before either. I thought about the sensor on the water pump to, but it's also only about 2-3 months old.
Old Aug 29, 2003 | 06:39 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Actually it should read "LO"(no "W" on mine)
most likely a sensor, I had the same thing with my oil temp a while back. It went on the fritz after a long drive through snow, but a few days later I guess it dried out or whatever since it is fine now.
Old Sep 3, 2003 | 07:47 AM
bwagner's Avatar
bwagner
Default Re: Temputer saying LOW????? (Mr Mojo)
Mines still doing it. Do you think it's the coolant sensor???
Old Sep 3, 2003 | 10:14 PM
Ramjet's Avatar
Ramjet
Just fixed mine from doing the same thing. It was the sensor on the front of the waterpump.. I cracked the connector when I installed the Crossbar.. :crazy:
Old Sep 3, 2003 | 10:28 PM
lt1_corvette93's Avatar
lt1_corvette93
I had the same problem with the sensor in front of the pump. At least your car was still running. Mine decided to die on the highway right before the tollbooth. They still make you pay for the toll even if you push your car through. I found that the plastic casing had separated from the metal sensor. I Pushed it back on the best I could and made it home thankfully.
Old Sep 4, 2003 | 12:57 PM
bwagner's Avatar
bwagner
Default Re: Temputer saying LOW????? (lt1_corvette93)
I'm going to change it this weekend, weather allowing, and see if that does the trick. Thanks for all the info guys!!!! :cheers:
To Temputre saying LOW?????
