more problems..
Old Aug 30, 2003 | 07:33 AM
jman1's Avatar
jman1
Default more problems..
My car seems to drop idle while driving.. It only happens when i let off the gas while the car is moving .. something like this ------___------ the car idles good when just sitting and runs great with no misses while accelerating or holding the gas pedal steady... sometimes the drop is two or three seconds before it jumps back up.... ???
Old Aug 30, 2003 | 07:45 AM
NicBig's Avatar
NicBig
Default Re: more problems.. (jman1)
Maybe a small vac. leak? Higher rpms hide vac. leaks.? I'm tapped out of ideas :sad:
Old Aug 30, 2003 | 08:52 AM
BIG JIM 54's Avatar
BIG JIM 54
You might check for a worn throttle plate shaft in your TB. It could be binding then feeing up, etc. Try lube then check. Just a thought.
BIG JIM
To more problems..
