new fuel pump for nitrous?
Old Aug 30, 2003 | 02:41 PM
fiberglasscoffin's Avatar
fiberglasscoffin
Default new fuel pump for nitrous?
has anyone changed there fuel pump or added an extra one i am looking to go bigger on the nitrous and im told i need a better feul pump setup?i have a fuel pressure gauge and its around 40psi at wot is that enuff i never see it drop unless just sitting still its around 38psi should i get an adjustable fuel pressure regulater to start should it be higher like 50psi or so?
Old Aug 31, 2003 | 10:31 AM
95AquaC4's Avatar
95AquaC4
Default Re: new fuel pump for nitrous? (fiberglasscoffin)
:yesnod: My kit from NOS came with one.
Old Sep 1, 2003 | 09:08 PM
fiberglasscoffin
Default Re: new fuel pump for nitrous? (95AquaC4)
ttt
Old Sep 1, 2003 | 09:19 PM
Half Fast's Avatar
Half Fast
Change your fuel filter. If your car is stock and you're spraying a 100 or less you should be okay. You definately do not want to run lean.
Old Sep 1, 2003 | 09:20 PM
Dan Parker '96's Avatar
Dan Parker '96
I added a Racetronix unit ( http://www.moreperformanceinc.com ). Look under Fuel.
It truly is the easiest mod for a C4 Vette. Takes about 45 minutes (even with adding the upgraded wiring) and the peace of mind is priceless.
fiberglasscoffin
Default Re: new fuel pump for nitrous? (Half Fast)
im using 150 and thinking of more
Old Sep 1, 2003 | 09:21 PM
BAM92's Avatar
BAM92
Racetronix makes a very nice kit. I just got mine in. Very nice wire harness with it. It is in tank also. Very affordable. :thumbs:
Old Sep 1, 2003 | 09:26 PM
Half Fast's Avatar
Half Fast
With a 150 you need to check it with a wideband O2 on a dyno.
Old Sep 2, 2003 | 03:24 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Hope you got the money put back for a rebuild or have good credit with VISA.
FWIW, if you increase the fuel pressure the Nitrous will run fat. I would expect your fuel pressure to be in the 42-44 range stock though (without the vacuum connected). The Walbro GSS340 (high presure) or the GSS307 are the pumps you want if you are planning on upgrading the stock in-tank pump.
Old Sep 2, 2003 | 07:34 PM
fiberglasscoffin
Default Re: new fuel pump for nitrous? (Vette92)
thanx for the info on the pumps (The Walbro GSS340 (high presure) or the GSS307 are the pumps you want if you are planning on upgrading the stock in-tank pump.)and if the motor blows i have great credit with visa and mastercard and discover and amex
:thumbs: i plan on building a strong bottom end in the next motor so it can take 200 to 250 without worry
Old Sep 2, 2003 | 09:08 PM
95AquaC4's Avatar
95AquaC4
That'll be some ride! :yesnod:
Old Sep 2, 2003 | 09:48 PM
fiberglasscoffin
i love the way the car feels when the 150 hits i cant wait to try 200 i might have to do it to the stock motor to blow it so i can build the new one :crazy:
To new fuel pump for nitrous?
