Tach Filter Bypass
Old Aug 30, 2003 | 04:25 PM
LD85's Avatar
LD85
Default Tach Filter Bypass
My tach starting going crazy when I went above 3200 RPNM so I put a jumper around the tach filter and to my amazement the tach now works :party:
I cant believe it was that easy. I did not take the filter out completely and may and just may leave it the way it is.
I read many post some saying it worked, and some psosts saying it does not work.
For me today it works, I just drove the car on a 50 miles round trip and now I can shift with "some" confidence in he readings. Tomorrow I will match the tach witha couple of Diacom runs for accuarcy. :seeya
[Modified by ld85, 4:25 PM 8/30/2003]
Old Aug 30, 2003 | 05:07 PM
1MoorTym's Avatar
1MoorTym
Default Re: Tach Filter Bypass (ld85)
My tach did the same thing when I put an Accel coil in the car. Put a stock one back in and it acted normal so I left it alone.
I thought about jumpering out the filter at the time but was too damn chicken that I'd screw up the cluster. Good to know it works OK without it.
Where'd I put that Accel coil.......
Old Aug 30, 2003 | 05:47 PM
87SAM's Avatar
87SAM
Default Re: Tach Filter Bypass (1MoorTym)
Mine does the same thing around 3200 rpm. If I remember correctly it also is an Accel coil (given to me some time ago). I was going to put the old coil back in to check if it indeed was the coil causing the problem. I may instead try this bypass feature. :)
Old Aug 30, 2003 | 06:54 PM
LD85's Avatar
LD85
Default Re: Tach Filter Bypass (87SAM)
I have the Accell Blaster Coil, I think thats what is is called, but it ran OK on the last Accell coil I had, so who knows what the real issue is, I'm just glad its OK.
Old Aug 30, 2003 | 07:50 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
My tach filter has been cut off completely, but that's a whole other story.
Old Aug 30, 2003 | 09:06 PM
LD85's Avatar
LD85
Default Re: Tach Filter Bypass (Mr Mojo)
Just took another cruise, the tach still doing its thing!
I am so pleased! :cheers:
Went to the local Dog N Sudes, must have been 250 cars there, yowsah!
Old Aug 31, 2003 | 09:58 AM
kertesz@swbell.net's Avatar
kertesz@swbell.net
1st Gear
Default Re: Tach and speedo problem
Speedo and tach on 88 are not working. Rest of cluster seems to be ok.
Other than problems with the cluster, are there any other elements that would affect the tach and speedo.
Old Aug 31, 2003 | 10:41 AM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
The ground wire from my tach filter is not hooked up. Where do I find it so I can hook it back up?
Old Aug 31, 2003 | 11:09 AM
LD85's Avatar
LD85
Default Re: Tach Filter Bypass (flyersfan1088)
ON my 85 I have one wire coming from the harness that goes to a connector on my steering coluim under the dash.
This wire goes up into a connector then into the FILTER, then out and into the distributor cover.
The ground in my distributor is the ceneter tab in the three connector plug and this tab is bent so that it goes under the coil so that the coil cover screw holds it down in place.
I do not know of a ground wire per-say, but I've been wrong before and often! :lol:
Old Aug 31, 2003 | 11:38 AM
flyersfan1088
My tach stopped working when I had my new torque converter put in. In Gordon Killebrews book for digital dash troubleshooting, he says that a 0 reading on the tach indicates a disconnected ground wire. He says this ground goes to one of the top bellhousing bolts. How in the heck do you get to this?
Old Aug 31, 2003 | 11:40 AM
LD85's Avatar
LD85
If that is where it is you can really only get to it easily buy takign your distributor cap off, then if you still cant get to it, mark your distributor with alingment marks and pull it.
To Tach Filter Bypass
